1957 1110906 Distributor Vacuum Advance ? - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11323
    I research here and found this thread:
    https://www.forums.ncrs.org/showthre...vance&uid=6654
    The new JG has no detailed info. Does this look like a 1116125 VA?
    It has a number "17" stamped on it, which could I assume is the pull spec
    There are no other numbers on it when on the distributor.
    Rich
    more pics here:
    Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
    • 43221
    Re: 1957 1110906 Distributor Vacuum Advance ?
    Rich
    more pics here:
    http://s684.photobucket.com/albums/v...l%20Injection/
    Rich------
    Yes, it does look like a GM #1116125. However, there were other vacuum controls that looked exactly like a GM #1116125. My expectation would be that somewhere on it, perhaps not visible with the unit installed on the distributor, there is a stamping that in some way identifies it as a GM #1116125 (or, something else).
    • James G.
      • May 31, 1976
      • 1556
      Rich
      more pics here:
      NICE 4520 unit Rick. I just sent your photo file to KEN KAYSER, kwkvette57@aol.com, (810) 691-4723. He has tons of history on these early units and has written a great book described here :http://www.tachometerpress.com/
      • Barry H.
        • April 30, 1976
        • 213
        Richard, Not to be critical, but your photo's seem to show a "dual point"
        fixed breaker plate with 2 sets of points. All of my recollections of "906" dists had single point moveable breaker plates. Yours looks like a "905" plate, solid mount & will not operate with a vacuum unit. If you need a "906" breaker plate, drop me a line. Probably have one in the old dist junk. Barry Holmes #940
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11323
          Hi Barry, I'm glad you noticed..........
          This belongs to a friend and someone asked about the vacuum advance part#. I don't know anything about these early FI distributors so this is good info. I didn't realize it should only have one point set, and I bet my friend didn't realize either. I'll tell him about it. Thanks for the information.
          Rich
          • Stuart F.
            • August 31, 1996
            • 4676
            My very first Chevy V8 (a 55 that I put in a 50 Chevy back in 1956) had a single point distributor with a vacuum advance (which I still have). When I got it running, it would cutout and completely go out of time when I reved it up. Turned out it was the point plate tipping and I temporarily curred it by disconnecting the vacuum advance. Could be that was a common problem with those early distributors, and was cause for the owners to change to the solid plate.
            In your friends case, the person who changed it out probably left the VAC can on to plug the hole only as the solid plate did not need the VAC to hold the plate still, as was the case with my temporary fix.
            Interesting.
            Stu Fox
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11323
              Stu, A likely scenario. Who knows why these things happened. I find myself wondering what future owners will be thinking of when they see what we have all done to these cars here in the present time.
              Rich
