L36 part? - NCRS Discussion Boards
L36 part?
+ More Options
Posts
  • John R.
    • November 1, 2005
    • 433
    L36 part?
    Can someone tell me what this is and where it goes? Looked in the 1967 AIM but could not find. Page in AIM would be nice, if possible. Thanks.
  • Mike M.
    • May 31, 1974
    • 8402
    Re: L36 part?
    bracket that retains the vac advance to carb tube?
    • Michael G.
      • January 1, 1997
      • 1251
      Re: L36 part?
      I was getting ready to say "throw out bearing".......
      • Jack C.
        • September 30, 1992
        • 1090
        Re: L36 part?
        I'm no C2 expert, but it doesn't look like the carb to v/a line clip.
        Jack Corso
        1972 Elkhart Green LT-1 Coupe 43,200 miles
        Top Flight 1994, 2018 & 2021
        • Stephen L.
          • May 31, 1984
          • 3162
          Re: L36 part?
          Definitely the vacuum advance metal tube holder. Held in place by a manifold bolt. Probably doesn't show up in the AIM as it came with the engine from Tonawanda.
          • Jack C.
            • 1090
            Re: L36 part?
            Doesn't the metal line clip onto the two small tabs. What is the function of the larger clamping portion at the end of the part?
            Jack Corso
            • Stephen L.
              • May 31, 1984
              • 3162
              Re: L36 part?
              Jack,
              My error! Didn't look close enough at the photo. That is not the vacuum advance tube holder for a standard 67 390/427. I don't know what the larger "clip" is for. Attached is a photo of the correct clip for the vacuum advance tube for a 390......
                • 43259
                Re: L36 part?
                Originally posted by Stephen Lavigne (7553)
                Jack,
                Steve, et al------
                The clip pictured here is the only type of manifold-mounted, vacuum tube clip that I am familiar with for both small blocks and big blocks.
                • Douglas L.
                  • August 31, 2003
                  • 302
                  Re: L36 part?
                  John,
                  I believe clip you have is a special designed clip for use on L36 motors with the Air Injector Reactor system.
                  The bottom clip is for the vacuum advance. The top clip is for the vacuum signal to the fuel mixture control valve.
                  • Douglas L.
                    • August 31, 2003
                    • 302
                    Re: L36 part?
                    John,
                    By the way, if you have an A.I.R. motor and need that clip, it is almost impossible to find.
                    • Jack C.
                      • 1090
                      Re: L36 part?
                      I learn something new every day. Nice pick up Doug.
                      Jack Corso
                        • 43259
                        Re: L36 part?
                        Originally posted by Douglas Lee (40617)
                        John,
                        Doug------
                        Looks like that's it. This clip would apply only to 1966-67 L-36 with K-19. I believe that other 1966-67 engines with K-19 used a different tube/hose routing and/or configuration. 1968+ with AIR used a different diverter valve set-up and the hose did not require or utilize routing through any sort of clip. So, this would be a very rare piece, indeed. I can't find a part number for it but I'll keep looking when I get a chance.
                        • Dennis S.
                          • April 1, 2004
                          • 228
                          Re: L36 part?
                          Here is a picture of what I believe is the original BLACK clip on my '69 L36. I don't have the A.I.R. system installed, but the larger clamp on the top facing the carb appears that it would support something for that system...
                            • 43259
                            Re: L36 part?
                            Dennis------
                            Maybe they were using up some of the 66-67 style clips for some period of time. In any event, the upper part of this clip would have had no purpose for 68+ with AIR but the rest of the clip would work just like the more common one in Steve's photo. As I mentioned, the only one that I've ever observed is the style like the one in Steve's photo. I must not have looked close enough.
                            • John R.
                              • November 1, 2005
                              • 433
                              Re: L36 part?
                              Thanks for the input. I do not think my L36 had K19, but...? It was delivered at Jim Rathman Chev in the Titusville, FL area. So, not a West Coast car, but not sure that would preclude it from having K19. Car is very original. Does have AC (C60), does that change anything?
