Help. 71 lt-1. Radiator shot so pulled fan, fan clutch and hood to get radiator,shroud,support out. Successful with help
from here and Corvette Forum(I am not mechanical but willing to always try so I follow the expertise given here- Thanks).
waiting on dewitts to attach tanks to their new copper core from Carlisle then would put everything back. But, with everything out, notice what appears to be oil all over the front of engine if you are looking at engine standing in front
of car.
Attached are pictures I took to show it. They are pictures where I see oil. Looks like (looking standing in front
of car) like oil on bottom half of left side (fuel pump side), some towards right side up below intake and by
head, and then heavy on right of timing cover. My friends thought the manifold(?) gasket was bad and oil was leaking
down and fan blowing everywhere. But when I look, it looks heaviest by timing cover?
Can you venture a guess please? My friends also told me to clean it, put everything back together(new radiator, heater
core(since that leaked too) and get that working. Then, since oil is cleaned up, I should see only new portions leaking
, after driving, which should make leak easier to diagnose where coming from. As stated, not mechanical but it seems
to me that is a lot of work just to find leak and take off equipment again(or maybe it is not and I am making a big deal sover nothing since I should be able to pull fan and clutch easily again even with shroud and new radiator in?)Point is I have no idea what I am doing or what is best or whether what I am
being told is best approach. So writing to experts-what would you do? Do as my friends say and clean it and get cooling system in and functional
and then trace leak or put in gskets(?) now while everything open and already apart?
Assuming it is a problem that requires gaskets(hopefully nothing worse), can someone recommend the right gaskets
to buy for manifold, timing chain or whatever you think is wrong, any sealants if necessary, and any tips tricks to putting whatever on. Thanks for all your help. Also please do not
assume I know anything so beg you to explain clearly or I will be like this-
pic 2 is oil on fuel pump side between fuel and timing
pic3 is up on drivers side below winters manifold
pic5 is driver timing chain which seems heaviest
pic 6 - should this be that dirty?
Final question - does anyone have any special cleaner they recommend?
Thanks in advance for your help.
Pete
waiting on dewitts to attach tanks to their new copper core from Carlisle then would put everything back. But, with everything out, notice what appears to be oil all over the front of engine if you are looking at engine standing in front of car.
. pic 2 is oil on fuel pump side between fuel and timing
Pete
You can always tear things down and replace seals and gaskets til you're blue in the face, but this really doesn't look that severe.
