This fan clutch came off my 66, L79.  Can anyone comment on whether this is aftermarket or what??  If someone could post correct 66 fan clutch photos that would be much appreciated.  I do not think this one is correct, but...
Also, when I took this off there were only bolts, no washers, holding the fan to the clutch. Is this correct?
Lastly, when installing the crank pulley I noticed the bolt head on the center mounting bolt (with the huge washer on it) has a hole in it. What is that for and should there be something run through it?
Thanks.
Thanks.
 Fan Clutch and Crank pulley bolt, 1966, L79
