55 Powerglide transmission - NCRS Discussion Boards
  • John F.
    • March 23, 2008
    • 2420
    I just purchased a 265 V8 w/powerglide transmission. The numbers on the tranny are (1) trans cover left front 3718251 GM26, (2) plate by filler tube 3709096 w/13 under it, (3) trans cover right side 3709050 GM 22X G317, (4) tail housing 3709096 w/13 under it. Is this both a passenger car/Corvette trans?
    John F
  • Karl L.
    • February 1, 1977
    • 174
    Re: 55 Powerglide transmission
    John,
    Got a couple hits on your numbers.
    Filler cover: #3709096 --- 55-57 Pass w/PG
    55-61 Vette w/PG
    58-61 Pass w/PG
    Ser. 10-20 w/PG
    GM Group # 4.105
    GM Group # 4.212
    Cover: #3709050 cast number GM #3713636 in book
    55-57 Pass w/PG
    55-57 Vette w/ PG 8cyl.
    Cast G 31 7 = July 31 1957
    I couldn't get a hit for the Tail Extension (taken from the thumb nail)
    Not in my book. There should be more numbers and dates on the main bodys.
    Karl.
      • 43279
      Originally posted by Karl Litzner (1264)
      John,
      55-61 Vette w/PG
      58-61 Pass w/PG
      Ser. 10-20 w/PG
      GM Group # 4.105
      GM Group # 4.212
      55-57 Pass w/PG
      Karl.
      Karl and John-----
      The 3708241 casting number on the extension identifies this as a 1955 Corvette and 1955-56 passenger car Powerglide transmission.
      The main case should have a casting number of 3708134 and/or 3708188 for a 1955-56 Passenger car and Corvette with V-8 transmission.
      • Karl L.
        • February 1, 1977
        • 174
        Joe and John,
        GP.4.103
        55-57 Pass Case w/housing 6cyl Cast #3708134-3719340 GM#3716692
        55-57 Pass/Vette 8cyl w/housing Cast #3719243 GM#3722299
        Didn't see number for Maincase #3708188
        Ext. Cast #3708241 GM#3713626 shows 55 Vette GP. 4.317
        Case w/housing 53-55 Vette 6cyl Cast#3703283 GM#3703522
        Karl.
        • John S.
          • July 29, 2009
          • 640
          on the pictures that were posted if we use the picture on the right, the main case number and date are on the bottom side of case. the converter case number is located on lowest right of the picture on the side of the converter housing. by slightly lifting the back of transmission this number is able to be read.
