54 Grill Teeth - NCRS Discussion Boards
54 Grill Teeth
  • Brad H.
    • August 12, 2007
    • 724
    54 Grill Teeth
    I ordered a No. 4 grill tooth for the 54 from CC and it is one that would go on my 58, only about 1 1/8 wide at the back, the 54 is 2 inch plus at the back, flares out more, 54-57 like this and where to get one Thanks, Brad.
  • Dan D.
    • November 5, 2008
    • 1323
    Re: 54 Grill Teeth
    Brad, I see no one has answered your question. Your description is somewhat confusing to me, but I believe what you are saying is you ordered a 53-57 grill tooth, but received a 58 instead. Sounds to me like CC sent you the wrong part. I would contact them, they have a simple return policy - no pre-authorization necessary. CC carries teeth for both configurations, so you should not have a problem with this. But be advised aftermarket teeth may not exactly match the original. But only very slight differences is in radius on edges I believe. Unless you need correctness for judging, then this should be okay and not be recognizable. -Dan-
    • Brad H.
      • August 12, 2007
      • 724
      Re: 54 Grill Teeth
      Thanks Dan, was going to call them anyway. thanks, Brad.
      • Brad H.
        • August 12, 2007
        • 724
        Re: 54 Grill Teeth
        Can someone measure their grill teeth on a 54 and tell me what the widest point at the flare is, mine is a little over two inch, the one C.C, sent me is about 11/8 and they say this is what they have always sold for the 54, the one thy sent me would fit on my 58. Thanks, Brad.
        • Dan D.
          • November 5, 2008
          • 1323
          Re: 54 Grill Teeth
          Brad, I will measure one of my 57 teeth for you today. The grill is out of the car and will be easy to do. It is stored in a different garage and I have to go dig it out.
          I looked at the Corvette Central site last night. I think it is incorrect in the way they list individual teeth. For complete grills they advertise 53-57 and 58-60 separately, but for individual teeth the say 53-60. I know 53-57 are the same, but 58-60 I believe are different. Perhaps someone can yea or nay this for me.
          I can't believe no one has chimed in on this for you. There are lots of 53-57 people on this forum and questions like this generally do not go unanswered this long. -Dan-
          • Brad H.
            • August 12, 2007
            • 724
            Re: 54 Grill Teeth
            I agree Dan, this is an easy one, wake up guys and give some info, Thanks again, Brad.
            • Gary C.
              Administrator
              • October 1, 1982
              • 17693
              Re: 54 Grill Teeth
              Brad, checked my 54-61 P&A's, Group 1.268 & all list tooth number 4 as part number 3706427 in use from 53-60. Measured an original 1957 (know it's original because I have a box of original grille teeth that I've taken off of '57's through the years) #4 grille tooth for you. Width across the widest part of the back is 1 3/8". Height is 7 3/16" tall. Side (spear tip to rear) is 3 11/16". Gary....
              NCRS Texas Chapter
              https://www.ncrstexas.org/
              • Dan D.
                • November 5, 2008
                • 1323
                Re: 54 Grill Teeth
                Thanks Gary, I did not get to measure one of my teeth today and I am going out of town tomorrow morning for the weekend and I was worried about leaving Brad hanging. -Dan-
                • Brad H.
                  • August 12, 2007
                  • 724
                  Re: 54 Grill Teeth
                  Guys, I was loooking at the setup of the teeth on 54 car just before heading out, seems they might be set in place wrong, will look at them Sun morning and respond back. Thanks, Brad.
                  • Brad H.
                    • August 12, 2007
                    • 724
                    Re: 54 Grill Teeth
                    Posistioning was fine, took off no. four (driver side) and it is a correct 4, it was a wider measurment at back side to side, about 17/8, maybe cause of age and overtight on and off through the years, it was cracked bad so bagged it and put on repro which measures about 1 3/16 across back, it is closer to other side meas. now with new tooth on. Thanks again for the info. Brad, now waiting my turn to get the correct soft top on the 58 and it is all done, white on blue with blue top.
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17693
                      Re: 54 Grill Teeth
                      Brad, FWIW Dave Brigham measured his original Bowtie '53 grille teeth and 1 thru 6 measure 1.35" and C is 1.5" wide. Gary....
                      NCRS Texas Chapter
                      • Troy P.
                        • February 1, 1989
                        • 1284
                        Re: 54 Grill Teeth
                        Is everyone in agreement that 53-60 teeth are the same, except that not all of them were used in later years? This is what I've always understood to be true.
                        • Brad H.
                          • August 12, 2007
                          • 724
                          Re: 54 Grill Teeth
                          Have not heard one way or another on this Troy, maybe someone will chime in, Brad.
                          • Jim L.
                            • September 30, 1979
                            • 1808
                            Re: 54 Grill Teeth
                            Troy, this has always been my understanding, too.
                            Jim
                            • Chris S.
                              • January 1, 2000
                              • 1068
                              Re: 54 Grill Teeth
                              there is a good explaination of the teeth in Nolans book......
                              size etc.....
                              1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
                              Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
                              1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
                              1957 Corvette - FI 3 sp - Black and Silver
