I had the intake gaskets changed last year for a similar problem. the gasket was leaking between 6 and 8. The has has been running great.
While driving the car recently and it running fine, it started to backfire and bucking when taking off . I nursed it home and after letting it cool down it seemed ok. However, after it is hot, I can now hear like an afterfire pop in the exhaust and the idle is not as smooth. It certainly seems to be a heat related problem. Do you think I could have an intake gasket problem again or should I look elsewhere? Points,cap, condenser, wires, etc were all new last year. Thanks for any input.
