C3 Bumper Washer Size - NCRS Discussion Boards
+ More Options
Posts
  • Sheldon S.
    • March 1, 1999
    • 478
    I am working on my 71 reattaching the bumpers, the flat washers that go under most of the attaching bolts is part number 9419276 and bolt number 9419075, 9419077. I have what I eleive to be an original washer and when I measure the outside diameter it is about 7/8 inch, the thickness appears to be about 1/16. It seems like a pretty light washer for some of the locations but it is the main washer listed. Is this the correct dimensions of the washer?
    Sheldon
    • 3416
    Re: C3 Bumper Washer Size
    Hi Sheldon,
    I looked at my notes about the bumper fasteners from my 71.
    I show the same size washers as you list. I even made mention on some of the notes that the washers were quite thin and the torque on the bolt had deformed the washer into a slight cup shape by being pulled down into the hole in the bracket. This note is for the fasteners for the bracket for the front bumper guards to the cross-member.
