Humidity and rebuilding an engine - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    Silly question, maybe.
    When rebuilding an engine is there any concern about high humidity and its effects on the surfaces of the engine components during and after the rebuild process?
    I was told there is.
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Humidity and rebuilding an engine
    Absolutely. Make sure that there are no bare steel surfaces. Rust can form within hours given enough moisture.
    A thin coating of oil is all that needed to avoid almost any problem.
    • Joe C.
      • August 31, 1999
      • 4598
      Perspiration dripped from ones forehead onto bare cylinder walls is moderately corrosive.
      There is a dandy product out there called "Blackburn's Sweat Net"................a kind of "thong" to protect your bicycle from damage due to droplets emanating from your genitalia. You can use one of these for each of your engine's 8 cylinder bores..............
      • David K.
        • February 1, 1976
        • 592
        OMG, why did I need to know that.
        • Stuart F.
          • August 31, 1996
          • 4676
          Real good information for us living in Hot/humid Florida. Now I know why my bicycle is all rusty. I thought it was from being in the dark corner of my garage.
          Stu Fox
          • Steven B.
            • June 30, 1982
            • 4001
            Try Flomax--
            • Timothy B.
              • April 30, 1983
              • 5196
              Sometimes the are certain images I just don't want to envision in my mind. Joe, you are a piece of work..
              • Tracy C.
                • July 31, 2003
                • 2739
                Joe...are you wearing one of these in your avatar pic? Those look like standard issue fruit of the looms to me..
                • Ray G.
                  • May 31, 1986
                  • 1189
                  Moderators: Please !!!!
                  I hope you dance
                  • William H.
                    • January 11, 2010
                    • 65
                    Yes humidity can shorten the life of your engine if not turned over every 6 months or so. I lived in Guam for a few years and the humidity there would rust the engine so bad as to not turn over any more in a couple of years. I don't think FL humidity is as bad as the south pacifc but it could be a factor.
