Auxiliary Hardtop window date code ? - NCRS Discussion Boards
  • Ray G.
    • May 31, 1986
    • 1189
    Hello;
    A back window Plexiglas date code of :
    lower left "B"
    upper right "F"
    is what date?
    JG shows lower left "B" with upper right "G".
    or
    lower left "H" thru "L" with an upper right "F"
    Thanks for your help.
    Ray
    I hope you dance
  • Timothy B.
    • April 30, 1983
    • 5188
    Re: Auxiliary Hardtop window date code ?
    Ray,
    I am not 100% but I think F is 1966 and B is month of February.
    • Ray G.
      • May 31, 1986
      • 1189
      Originally posted by Timothy Barbieri (6542)
      Ray,
      Hello Tim;
      Your correct w/ "F" being '66 and "B" is February.
      Am I reading the "Date Code Chart" incorrectly when concluding the lower left and upper right letters letter codes must be on the same row.
      The hardtop is a factory vinyl covered. Suppose it is possible it was covered aftermarket, but think it is Typical Factory Production.
      Ray
      I hope you dance
      • Wayne M.
        • March 1, 1980
        • 6414
        Originally posted by Ray Geiger (9992)
        ... Am I reading the "Date Code Chart" incorrectly when concluding the lower left and upper right letters letter codes must be on the same row. ....
        Ray -- not sure what you mean by "on the same row" if the year is lower left and the month is upper right.
        Big pic shows May of 1965 -- this one's easy; no chance of error in mixing year/month position .
        • Ray G.
          • May 31, 1986
          • 1189
          Hello Gentlemen;
          Thank you.
          Should have explained I meant the same row on the chart in the '67 JG chart, page 53.
          Think now upper right letter ("E") in your example is always the year.
          ie; "E"='65 "F"='66 "G"= '67 .etc.
          Was reading much more into the chart than necessary.
          Your help is appreciated.
          Ray
          I hope you dance
