T-10 shifter ID - NCRS Discussion Boards
T-10 shifter ID
  • Doug F.
    • November 1, 1983
    • 322
    T-10 shifter ID
    got this borg warner trans and shifter with a 58 i bought recently, anyone know what the shifter is from, 13 " tall, 5/8 " shaft as opposed to the 1/2 " shaft most passenger cars and old vets have, thanks
  • James G.
    • May 31, 1976
    • 1556
    Re: T-10 shifter ID
    Looks like passenger car, bench seat, "Spaghetti" shifters used from 1957 thru 62.
    What are the numbers on the case, tail shaft and side cover? Same trans for both years, but dates will apply to the correct year. I have the numbers if you need.
    Hard to find 57 and 58 'real' units. Only 664 in 57 and 3764 in 58 made it to Corvette production.
    • Steven B.
      • June 30, 1982
      • 4015
      Re: T-10 shifter ID
      Doug, your shifter looks like the '61 passenger car shifter I have and was bought in '61.
      Steve
      • Cecil L.
        • May 31, 1980
        • 450
        Re: T-10 shifter ID
        I believe the thicker shaft pass shifter was Pontiac, 62-63. Could be 63 Chevy also. I have 30 or 40 of those pass shifters in several variations and haven't got them all identified yet.
        • Eric V.
          • November 1, 1974
          • 53
          Re: T-10 shifter ID
          Doug,
          If you stand behind the tailshaft of the transmission and look at the shifter handle does it have a bend near the base that causes the handle to lean to the right (passenger side of car) about 5 degrees? If so, it is a shifter for a '61-'62 (and maybe '63 as well) Pontiac full size car with bench seat. '61 and '62 and I think '63 Pontiacs used a bellhousing with a bolt pattern that rotated the transmission about 5 degrees to the left, so the floor shifter handles had a bend near the base to compensate. The Chevrolet bench seat passenger car 4-speed shifter handles did not have this bend. I happen to be looking for the Pontiac shifter (or just the handle) to use in the restoration of my '61 425A Ventura.
          Eric V.
          • Joseph T.
            • April 30, 1976
            • 2074
            Re: T-10 shifter ID
            Doug /Cecil
            I have a 61 Chevy Bubble Top..I am building and could use a bench seat shifter.
            I dont need anything exotic or rare just something that works.PM me if you can help.
            Doug...I have complete experimental 0 dash casting # all cast iron T-10 4 spd and original shifter if you need pictures. This 4 speed is one of the earliest. I have not seen another except for the picture of one in Nolands book. I had it on display at the Bloomington Special Collection in 2007..and one observer pointed out the size of the cross shafts were larger than later T-10's even other known original 57 T-10's.
            Joe
            • Doug F.
              • November 1, 1983
              • 322
              Re: T-10 shifter ID
              nice info thanks for all of you're input
              • Cecil L.
                • May 31, 1980
                • 450
                Re: T-10 shifter ID
                Originally posted by Joseph Trybulec (930)
                Doug /Cecil
                Joe
                Joe.
                I sent you an email about the shifter with my addy.
                I have seen a very early cast iron T-10 with a 56 casting date. Don't remember if it was an 0 casting, but probably was. It belonged to Bob Flack (Pioneer Classic) here in Phoenix.
                • Joseph T.
                  • April 30, 1976
                  • 2074
                  Re: T-10 shifter ID
                  Originally posted by Cecil Loter (3596)
                  Joe.
                  Cecil..I heard about a Oct/Nov dated
                  T10 out that way. If Bob still owns
                  It I would like to trade pictures with
                  Him .
                  Joe
                  479-435-1855
                  • Cecil L.
                    • May 31, 1980
                    • 450
                    Re: T-10 shifter ID
                    Him .
                    Joe
                    479-435-1855
                    I don't see Bob much since he closed the shop. I think he and Darla moved to Prescott. He usually shows up at one our few local annual swap meets. When I see him again I'll ask.
