1962 WCFB Inlet Fitting - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11370
    Does anyone have a photo of the 3191S (250 hp base '62) inlet fitting face? What connects to it, a 1/4" NPT or a 5/16 (or 3/8"?) flare fitting?
    Pic left is from a mongrel WCFB(inverted flare), right is (1/4" NPT) from a used 3191S I just rebuilt. Which is correct, if either?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11370
    Re: 1962 WCFB Inlet Fitting
    dasdkjvosodpov
    • John F.
      • March 23, 2008
      • 2424
      I don't have time to check mine right now. I'll try to look at tomorrow.
      John F
      • Kenneth F.
        • September 30, 1988
        • 285
        My 1962 WCFB fitting looks like yours on the left. The tubing O.D is 5/16"
        Ken
          • 43293
          Rich------
          I can tell you that all 1959-64 Corvette and passenger car applications with single 4 barrel Carter carburetor used the same inlet nut. It was GM #3759759, aka Carter #15-70S. It was discontinued from GM SERVICE without supercession in August, 1981.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11370
            OK, Thanks.......It appears the left pictured flare type is the correct one. I'm not sure what the one on the right side is but maybe for AFB or AVS.
            • Stephen R.
              • May 20, 2008
              • 302
              I have a WCFB with an inverted flare fitting and room for the "brass" filter behind it, your pic on the left. My AFB has the straight in 1/4 tube fitting with no room behind it for the filter. Hope that helps.
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11370
                Yes this carb had the brass filter too with the spring behind it, but the fitting was NPT. It looks fairly knew, but I have no idea what it is or it's maker.
                • Stephen R.
                  • May 20, 2008
                  • 302
                  If you ever find out what it is, let me know, I could use a couple for my WCFB. I much prefer the direct pipe instead of the flare.
                  • Stuart F.
                    • August 31, 1996
                    • 4676
                    I don't know, perhaps my mind is slipping, but I can't ever recall seeing a factory NPT fuel fitting for a direct steel tube fuel line connection. The only thing that comes to mind is, as you say on a 62, would be their use of an NPT tube to an inline fuel filter. The only other application I know of would be for an aftermarket fuel hose fitting that we all used on multiple carbs back in the day.
                    Stu Fox
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11370
                      Yes I have not seen a NPT fitting like that ever myself......well, before this one. Here's a picture of the finished carb the new owner sent me with a GF-48 hooked up. Makes a nice easy/clean install IMO.
                        • 43293
                        Richard------
                        This set-up appears to have an adapter between the carb inlet fitting and the NPT bushing. It might be a double bushing, too, but I expect it's an adapter. In any event, I don't think a set-up like this was ever used in PRODUCTION.
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11370
                          Joe,
                          Yes I agree the GF-48 was never used in production for the 250HP, only the brass "stone" filter in the carb inlet housing. IMO I think it should have been a GF-48 in production though.
                          This setup is incorrect as far as we are concerned, but the owner wants functionality. In fact, I think it's a good idea........to see all of that sediment in the glass coming from the fuel system due to today's fuels!
                          I am planning the same setup for a friend's '59 I'm restoring.
                          • Stuart F.
                            • August 31, 1996
                            • 4676
                            My only concern would be air cleaner clearance. If it fits - great! However, most Corvettes have low profile air cleaner housings that fit down below the air horn gasket surface. My 63 is a prime example. I had to use an angled fitting right out of the carb (similar to stock) to get down below the housing and adjust it until the housing did not rest on it (I jacked my carb up with a 3/8" spacer and had to use a hose to reach the filter mounted at the stock water manifold location).
                            Stu Fox
                            • Bob B.
                              • March 1, 2003
                              • 832
                              Rich,
                              I'd watch out on the generous use of teflon tape. You were concerned about sediment. Theoretically, the fittings are supposed to seal without the tape. But, if you put the tape too far forward on the fitting, pieces can come off and, if a piece gets in your needle seat, then the gas flow into the carb won't shut off.
                              Bob
