1966 Build Date - NCRS Discussion Boards
1966 Build Date
  • David J.
    • August 19, 2007
    • 65
    1966 Build Date
    My '66 convertible has a serial number that falls in the middle of the numbers listed for February 1966. The Body Identification Plate indicates that the car was built on March 7, 1966 (G07). I am curious about what appears to be a difference in the February serial number and the March build date.
    Secondly, I am in the process of locating a new engine for the car. How do I determine which engine casting date for the block would match the serial number and build date?
    I would be appreciative for some clarification on these issues. Thanks.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1966 Build Date
    Originally posted by David Jarvie (47720)
    My '66 convertible has a serial number that falls in the middle of the numbers listed for February 1966. The Body Identification Plate indicates that the car was built on March 7, 1966 (G07). I am curious about what appears to be a difference in the February serial number and the March build date. ...
    For 1966 model year, Dow-Smith bodies, G is February; for St.Louis bodies, it's March. I suspect your body number on the trim tag is A-xxxx rather than Sxxxx.
    • Steven S.
      • August 29, 2007
      • 571
      Re: 1966 Build Date
      From what I have observed on some other 66's is that a month prior to the cars build seems to show up a lot, although there are other variables to take into consideration.
      Steve
        Re: 1966 Build Date
        Steve
        Steve -
        That's because there's a month difference in the 1966 body build date coding (using the same letter) between St. Louis bodies and A.O. Smith bodies. You can't use the trim tag build date as the car's final assembly date on an A.O. Smith body.
        • Steven S.
          • August 29, 2007
          • 571
          Re: 1966 Build Date
          John, I was actually referring to an engine casting date vs. cars build date (I should have been more specific).
          Steve
          • Rich G.
            • August 31, 2002
            • 1397
            Re: 1966 Build Date
            David
            I assume you have an AO Smith body. My 66 St. Louis vert is F07 and is 13251. I'm curious how close your VIN is to that.
            Rich G
            • Joe R.
              • May 31, 2006
              • 1822
              Re: 1966 Build Date
              David,
              On part two of your question, I would suggest plugging the last five digits of your VIN number into one of the online birthday calculators. There's one on this web site somewhere (my work browser is blocking access for some reason):
              The St. Louis Chapter of the National Corvette Restorers Society (NCRS) is comprised of Corvette enthusiasts with preservation & restoration
              You want a block casting date that fits the NCRS six month rule, no more than six months older than the car's birthday, definitely not newer. Make sure the casting number is correct, too.
              Good luck,
              Joe
              • Rich G.
                • August 31, 2002
                • 1397
                Re: 1966 Build Date
                David
                If your car is a small block, you could reference my numbers on the engine.
                Body build F07 St. Louis. Serial #13251 (Feb. 6,1966)
                Block cast date A126 (Jan 12, 1966)
                Assy stamp F01020HT ( Flint, Jan 20, 1966, 327/350 L79 Holley, 4 speed)
                Casting #3858174
                As posted before, judging allows up to 6 months before build date for components, but the dates have to make sense so that the cast date is before the assy date, for example.
                Last edited by Rich G.; September 2, 2010, 10:56 AM. Reason: A126 is Jan 12, not the 26th
                  • 15599
                  Re: 1966 Build Date
                  Originally posted by Rich Gianotti (38594)
                  David
                  Block cast date A126 (Jan 26, 1966)
                  Casting #3858174
                  Not to be too picky, but that cast date comes out to Jan 12, 1966, and THAT date will work much better with the assembly date you posted.
                  • Rich G.
                    • August 31, 2002
                    • 1397
                    Re: 1966 Build Date
                    Thanks....not too picky...never too picky when there is a mistake. I read that twice before I posted it and still got it wrong.
                    Like my friend the carpenter says: "I cut it TWICE and it's still too short"
                      • 15599
                      Re: 1966 Build Date
                      LoL
                      I'll have to remember that one -- especially when I goof up at work. The bosses tend to take a dim view of those kinds of events and a bit of levity sometimes helps.
                      • Mark L.
                        • 560
                        Re: 1966 Build Date
                        Dave, If you want to get an exact date you can request the GM Shipping Data Report which will also include the dealer number and name. The web site will be set up to accept requests starting October 1.
                        • David J.
                          • August 19, 2007
                          • 65
                          Re: 1966 Build Date
                          I want to thank everyone for their input regarding my build date question. As always, I am amazed at the wealth of knowledge available from members.
                          Dave
