I have an original tach cable for a 58 290 HP with the steel casing with the threading nuts labelled A/C Speedometer on one end and A/C Sparkplug on the other.
On the tach end, it has a sort of keyway/projection and the other end is a four saquare contact. Did this keyway/projection/?? go away before 1962 in some sort of running change or ??????
