Clean up of 1956 gas cap - NCRS Discussion Boards
  • Alexander C.
    • June 20, 2010
    • 353
    My car still has it's original gas cap which I have verified. It needs to be cleaned up though and the gasket replaced. I don't even know what type of metal it's made out of or what the finish should look like. I don't want it fully restored, just cleaned up a bit.
    Any idea what cleaner would be safe and not ruin the patina? Also where can I buy a correct gasket?
    Thanks!
  • Mike G.
    • July 31, 2002
    • 709
    Re: Clean up of 1956 gas cap
    light bead blasting being carefull not to damage the cad finish. top and bottom. i used about 50 psi and hold it at a distance working a little at the time.
    • Bruce B.
      • May 31, 1996
      • 2930
      After the light blasting or cleaning with Scotch Brite apply some silver "Rub and Buff", wait a few minutes and then buff with a soft cloth.
      The appearance is similar to cad plate.
      Rub and Buff is available at craft stores.
      • Richard T.
        • February 1, 1979
        • 858
        I've used the Eastwood cad system on gas caps and other small items and have been very pleased with the results. Rich
        • Alexander C.
          • June 20, 2010
          • 353
          Thanks for the suggestions!
          • Gary H.
            • June 30, 1980
            • 155
            Try soaking the cap in a solution of Simple Green, it should take a day or two to clean up like new.
