'56 Turn signal lever - NCRS Discussion Boards
  • Loren L.
    • April 30, 1976
    • 4104
    I am now, courtesy Bob D'Olivo, in possession of the turn signal lever that was removed from the Dick Jess/Racer Brown/Bob D'Olivo '56 racer that Dr Dick Thompson drove to clinch his '56 National Championship in CP at Palm Springs.
    It's condition, as you would expect from a piece removed from a car less than 7 days old, is very, very nice. There is a seam in the white plastic in the center of the knob - is this normal, strange or subject to a running change down the road"?
  • Mike M.
    • May 31, 1974
    • 8408
    Re: '56 Turn signal lever
    normal, but you are not. regards,mike
    • Loren L.
      • April 30, 1976
      • 4104
      Ah, yes, it's H___ to be slow.
      Bus back from Carlisle early?
      Started on the Cheetah tractor yet? You need to put out a little checklist for what to tell IRS about these "farm vehicles" that show up on your "farmer/dermatologist" return...........
      • James G.
        • May 31, 1976
        • 1556
        You missed BEND Loren. Mike.....DipStick.....Burt Lukens.....Brian Futo....and yes even Roy Bratz leaving early. And I never went into the Bar, cause they all said you were causing to much trouble "hacking" the hotel computers from Az.
        • James F.
          • December 1, 1985
          • 596
          Loren, White/cream plastic part of '56 turn signal lever all have a seam due to he mfg. process. Regards, Jim
