1970 LT-1 Valve Lash, Idle and Idle Mixture Setting - NCRS Discussion Boards
  • Wolf S.
    • July 15, 2009
    • 94
    #91
    eat my dust
    • Timothy B.
      • April 30, 1983
      • 5202
      #92
      Re: 1970 LT-1 Valve Lash, Idle and Idle Mixture Setting
      The chugging may be a little to much advance, how much vacuum advance is the B-28 providing. You can install a rubber bushing on the end to limit the travel hence less vacuum advance. All looks good though IMO.
        • 15706
        #93
        Two other things to check are total idle advance and total cruise advance.
        With the VAC connected how much advance at idle speed?
        Total idle advance = intial, plus full vacuum, plus maybe a couple of degrees of centrigual if it starts below idle speed, but you data say it doesn't if you idle at 900 - should be a about 30-34.
        Then with the VAC also connected rev the engine to 3000, which is above where the centrifugal is all in.
        Total cruise advance = initial plus full vacuum plus full centrifugal - should be 50-54.
        Your data only indicates a total of 22 centrifugal, OE spec is 26.
        In what gear and at what RPM is the engine not smooth at constant cruise speed on level ground?
        • Wolf S.
          • July 15, 2009
          • 94
          #94
          eat my dust
