67 gas tank overflow tube position - NCRS Discussion Boards
  • Charles S.
    Infrequent User
    • August 16, 2010
    • 15
    I am replacing the gas tank overflow tube in my 67 coupe and I'm not sure exactly where the lower end should be positioned. I think it is someplace in the decending section of the right bumper. But is it just at the top of that area or does it go almost all the way to the bottom of that vertical piece of the bumper?
    _________________________
    Ray
    1967 327/350 HP Coupe
    (Bloomington Gold Survivor 2010)
    (NCRS Top Flight Award 2010)
    2005 Coupe
  • Rob M.
    • April 30, 2003
    • 657
    Re: 67 gas tank overflow tube position
    Charles,
    I believe it's the same as the '66 and will be almost flush with the bottom of the bumper.
    Good luck
    Rob
    '66 327/300 Regional Top Flt
    '08 6 speed coupe
    • Charles S.
      Infrequent User
      • August 16, 2010
      • 15
      Thanks for your help
      Ray
      2005 Coupe
      • Kirk M.
        • June 30, 2006
        • 1036
        My original 67 tube which contains a spring it stops about 2 inches or so from the end of the bumper edge.
        Kirk
        • Michael J.
          • January 27, 2009
          • 7181
          Kirk
          Right, and don't forget that spring. The positioning of this tube is another Bubba engineering by GM. When it overflows it pours right on your foot, great design.
