68 Vacuum Tank Pressure Question - NCRS Discussion Boards
  • Jeffrey A.
    • October 22, 2006
    • 273
    My 68 is a 427/390 a/c coupe. I am currently getting ready to test my vacuum tank and system . I first want to her my tank it vacuum. Does anyone no what type of vacuum should I making and holding in my vacuum tank. I am going to put a gauge on the tank to check it.
  • Michael W.
    • April 1, 1997
    • 4290
    Re: 68 Vacuum Tank Pressure Question
    Should be pretty close or equal to manifold vacuum.
    • Jeffrey A.
      • October 22, 2006
      • 273
      Thanks Mike, I am holding 12 pounds of vacuum.
        • 15601
        I am trying real hard here not to be a wise a$$, and I am failing
        Pressure is measured in pounds per square inch in the USA
        Vacuum is measured in inches of mercury in the USA.
        If you are holding 12 pounds you are most likely in the gymnasium. I would think it is pretty hard to hold 12 pounds of vacuum, but I can't say I have ever tried.
        • Jeffrey A.
          • October 22, 2006
          • 273
          Typo on my part I meant Inch pounds, thanks for the correct. I was just wondering what type of vacuum should I have to run the system. I am going through the system now to find out if a leak in a hose or a fitting.
            • 15601
            Engine vacuum can be anywhere from 12 to 18 inches -- depending on the engine state of tune and speed. On coast-down on a hill the vacuum could perhaps get to 20 inches, but not too often. I don't know what you are using for a vacuum pump, but anything that sucks more than 25 inches is overkill.
            • Jeffrey A.
              • October 22, 2006
              • 273
              Thanks Terry. Got my system working today. Thanks again for the help.
