72 half shaft u-bolt finish - NCRS Discussion Boards
    • 11643
    On the orange 72 I'm replacing the u-bolts that hold the half shafts to the differential. Were the originals natural (bare) steel, black phosphate or zinc? The replacements I just received are natural with a bit of mild surface rust, and I'm trying to figure out if I need to clean them and oil them, or treat them with black phosphate. I don't "think" they were originally zinc.
    No notation in the JG, and the originals were just "rust" when I removed them.
    Patrick
    • 43220
    Re: 72 half shaft u-bolt finish
    Patrick
    Patrick------
    Originals were black phosphate.
    By the way, you can still obtain the u-bolts under the original part number of GM #2066840 (for about 9 bucks, each, GM list).
      • 11643
      Patrick------
      $9 eh?
      Ouch. ($5.15 + exhorbitant shipping cost at gmpartsdirect)
      Easier to make these black phosphate, especially since I have other bolts to do.
      Were the connecting nuts the same color?
      Patrick
        • 43220
        $9 eh?
        Patrick
        Patrick------
        The nuts had a "plain" finish. This does not necessarily mean a shiny metal. It just means that no surface finish was applied. Usually, they are sort of a gray to light brownish coloration. These nuts, GM #103026, were 3/8-24, 21/64" thick, and of GM 286M material grade (SAE grade 5).
        The split lockwashers used were GM #103321. They were of 43/64" OD, 25/64" ID, and of plain finish.
        Make sure you get the above just right. Future judging "trends" are going to focus on these pieces and they'll receive intense scrutiny.
          • 11643
          Patrick------
          LOL!
          Most of the time I'm a chassis judge, and I can't even tell what finish they're supposed to be! Often, "rust" is the correct answer just as in my case.
          Thankfully this car is meant to be driven, though I suspect he may have it judged once.
          Patrick
