1962 correct Rocker panel mounting screw - NCRS Discussion Boards
  • Anthony P.
    • June 27, 2010
    • 485
    The AIM indicates screw #168495 with a flat spring nut on the back used to secure the face of the rocker panel in the front and rear.
    I have been unable to find out exactly what size this screw is.. Is it flat or pan head, length, size, finish, material, etc?
    Any help?
    Tony
  • Doug F.
    • November 1, 1983
    • 322
    Re: 1962 correct Rocker panel mounting screw
    i believe a # 8 chrome counter sunk oval head would do the trick, much like a door panel screw
    • Anthony P.
      • June 27, 2010
      • 485
      thank you.
