Can't find some 67 parts - NCRS Discussion Boards
  • Keith G.
    • October 31, 2006
    • 316
    I need the plastic sleeve that goes on the steering column, under the dash. Didn't see them in LI or Paragon. Also at a NCRS meet, they told me I needed some king of anti-rattle cushion that I THINK goes on the under side of the roadster deck-lid, not very clear on that.
    • 43246
    Re: Can't find some 67 parts
    Keith-----
    The plastic screen, discontinued by GM eons ago, is practically impossible to find. As far as I know, it is not reproduced.
    • James C.
      • April 1, 2002
      • 7
      Go to a junkyard and find a 1967 Gm steering column, cut plastic cover off and reconstruck to fit 67 Corvette.
      • Ronald L.
        • October 18, 2009
        • 3248
        Is this the same as 66 column?
        Send me a picture
          • 43246
          Send me a picture
          Ronald-----
          No, I don't think that 66 used a collapseable column whereas 1967 did. The plastic shield was associated with the collapseable feature.
            I wager a guess that the judges were referring to die-cut rubber pads about 1-inch square that have been seen on the bottom side of some convertible deck lids just above the folded front header bar latch handles. Some of the mid-year JG books cite these 'bumpers', but others of us scratch our heads.
            Why? Well, take your copy of the '67 AIM, flip to UPC 1, Sheets F6-F7 where the rear deck lid is being assembled. You'll note the ABSENCE of a part call out for these bumpers. Same for '65 and '66...
            So, some of us question if these were actually installed on all factory production cars vs. installed on exception either at the plant or dealership. But, you'll find them listed by some of the parts catalog houses and we HAVE seen some, apparently untouched cars, with the pads installed...
            • Charles A.
              • July 31, 1980
              • 180
              Any body find where plastic covers for 67 column can be located?
              • Keith B.
                • March 7, 2008
                • 928
                as someone said a junk yard with 67+ GM columns. also I think some mopars had them
                • Chris E.
                  • November 3, 2006
                  • 1331
                  Keith,
                  What anti-rattle piece are you talking about? Was that on your interior sheets from this weekend?
                  Chris Enstrom
                  2011 Z06, red/red
                  • Stephen L.
                    • May 31, 1984
                    • 3159
                    My 73 B body Mopar has the plastic sleeve. Appears to be the same as the sleeve on my 67 Vette. A junk yard visit will probably yield many.
                    Pictured below are the MOPAR sleeves
                    A 67 column and sleeve can be seen here for comparison; https://www.forums.ncrs.org/showthre...62706&uid=9638
                    • Keith G.
                      • October 31, 2006
                      • 316
                      I have some extra dust covers now.
                      • Philip C.
                        • December 1, 1984
                        • 1117
                        Hi Keith if your going to Carlisle next week stop by my spots G-91 G-92 I should have one. Phil 8063
                        • Charles A.
                          • July 31, 1980
                          • 180
                          Actually I need the sleeve. Email me direct carnold@coj.net with price and I will have a friend (Larry) stop buy and get it.
                          • Joseph M.
                            • June 30, 1999
                            • 334
                            You can also try Corvette USA (Americas Finest). Mike advertises in the Driveline and usually has some of the hard to find pieces.
                            • James W.
                              • December 1, 1990
                              • 2662
                              Keith,
                              These are the anti-rattle pads found on the underside of the convertible deck lid. These pictures were taken from an unrestored 1965 convertible VIN 2209x.
                              James West
