C-4 Parts - NCRS Discussion Boards
C-4 Parts
  • David L.
    • December 1, 1981
    • 116
    C-4 Parts
    A few months ago I posted my intent to purchase a C-4. I found a 35,000 mile beauty after weighing the pros and cons as contributed by members on the TB. Now my question is, what should I be squirreling away in anticipation of parts failing in the next several years? Any who have experiences they wish to relate will be greatly appreciated. I hope to narrow this down to a short list since I understand the C-4's have more parts included in their build then any other generation. The car has the tuned port engine with the 4 speed, three speed manual transmission. Also, what does GM stock or where I might go to find specific parts.
    David
  • Pat M.
    • April 1, 2006
    • 1579
    Re: C-4 Parts
    David that's a great question I wish I knew the answer to. I've bought as many hoses and other similar perishable parts still available I could think of for my 96 from my local dealer.
    Unless you can find an exhaustive list by people far more knowledgeable than me, I'd go to my local dealer and simply see what's still available.
    Good luck.
      • 43246
      Re: C-4 Parts
      David
      David-----
      I don't think that your dealer is going to be able to provide any sort of list as to what parts remain available for your car. It would also be very time-consuming for myself or anyone else to provide you with such a list.
      In general, you are going to find that the list of GM-available parts for a 1989 or earlier C4 is going to be quite limited. As far as interior or trim parts, the list is going to be VERY short. As far as mechanical, electrical or suspension parts, there will be some still available and others that are discontinued might be available from the aftermarket.
      So, what to concentrate on acquiring? Well, my suggestion is to focus on wear or life-limited parts that are Corvette-unique and especially those that were only used for a few model years.
      • David L.
        • December 1, 1981
        • 116
        Re: C-4 Parts
        Thanks, Joe and Pat. I figured I'd get the answers you provided. Guess I'll just play it by ear and buy when something comes available that I might need in the future.
        Problem is, I don't know what I might need.
        David
          • 43246
          Re: C-4 Parts
          David
          David-------
          As Shakespeare once wrote "aye, there's the rub...". My solution (albeit and expensive one)? Buy EVERYTHING! That's how I ended up with 14,800 NOS parts (and counting).
          • Pat M.
            • April 1, 2006
            • 1579
            Re: C-4 Parts
            David I started by simply raising my hood and making a list of every reasonably perishable thing I could see and then asking my dealer if it was still available. To my surprise most were.
            Another angle I used is to ask a mechanic who works on C4s what parts he can think of that are difficult to get. You might be surprised how many parts he may be able to name off the top of his head.
            • Patrick N.
              • March 10, 2008
              • 954
              Re: C-4 Parts
              TSB's can also give a clue. Overall, my C4 has been great mechanically, other than replacing the obvious tin-shim intake manifold gasket, headlight motor gears and the rear hatch solenoid. It's my driver and it has been very reliable! The top targa plastic can craze overtime and crack ,that is a good one to find NOS.
              Nose and gas cap emblem fade something fierce so I have a new set.
              Pat
              • David L.
                • December 1, 1981
                • 116
                Re: C-4 Parts
                Thanks, Patrick. I've recorded your comments. The C-4 graveyard sounds like an excellent source.
                David
                • Patrick N.
                  • March 10, 2008
                  • 954
                  Re: C-4 Parts
                  glad to help,
                  Check out contemporarycorvette website and view the Wreck of the Week section-it's something to behold
                  • David L.
                    • December 1, 1981
                    • 116
                    Re: C-4 Parts
                    I've bookmarked the site. Thanks! Hopefully, this type of information will continue to come in and I can compile a resource list. The '85 wreck is basically the same car as mine. Hope it never ends up looking like that!
                    David
                    • Jim W.
                      • November 1, 1994
                      • 94
                      Re: C-4 Parts
                      David
                      David, I have a C4 and the one really 'Hard to find' was the brake master cylinder, followed by some interior parts. Good Luck !
                      Each day is a gift, respect it, and enjoy it as if it were the last!
                        • 43246
                        Re: C-4 Parts
                        Jim------
                        The interior parts I can understand. However, difficulty finding the master cylinder surprises me. The 1984 master cylinder is still available from GM and Delco under the original part number of 14046850, aka Delco #174-836. Alternately, a virtually identical master cylinder is available under GM #18030473, aka Delco #18M231.
