Trailing arm install - NCRS Discussion Boards
  • James H.
    • February 22, 2007
    • 130
    Well it came out without much profanity. Now that its time to go back in, is there anything I should watch out for on the 67. Planned on putting shims back as they came out.
    Jim
  • Alan D.
    • January 1, 2005
    • 2046
    Re: Trailing arm install
    Jim hope you measured the old bushing's thickness. Most repo's seem to be a little larger so all the original shims will not fit any longer. However if that turns out to be the case just take an equal amount off each side from the original shims.
    • Wayne P.
      • January 23, 2008
      • 444
      I would replace old bolt and nut with a new one. Don't fully torque till the weight of the car is sitting back on the ground. My two cents worth. Good luck. Ps check for rust in the kick up pockets good time to repair .
      I started to replace trailing arms and ended up replacing the frame.
      • Brian M.
        • February 1, 1997
        • 1840
        Use slotted shims. JMHO.
        • Larry M.
          • January 1, 1992
          • 2700
          A good idea. But frame should also be drilled and the EXTRA-LONG cotter pin installed at the same time. This will help to keep the shims from coming out when car is driven.
          Larry
            EXCELLENT advice (slotted shims) but only good IF your objective is driveability and low maintenance vs. factory/correct concours judging results...
            The early cars that used double hole vs. hole + slot style shims are checked by savvy chassis judges for this level of factory authenticity.
            • Gary J.
              • April 1, 1980
              • 1244
              By using the slotted shims you are taking a chance of them falling out. If it were me and I had the orginal ones that would be what I would use. It will a little more aggravating installing the original one, but you would have a piece of mind that they would not be falling out.
              • Larry M.
                • January 1, 1992
                • 2700
                Gary:
                If you use the slotted shims AND the "long" factory installed cotter pin, they will not fall out. They are secured by the pin. The slotted shims have a secondary hole just for this purpose.
                I believe GM started doing this around 1970 (+/- 1 yr).
                Larry
                • James H.
                  • February 22, 2007
                  • 130
                  I'm hoping to reuse existing shims BUT can someone show a pic of how a long cotter pin holds the slotted shims from coming out.. I dont understand.
                  Thanks for all the information. Unfortunately I didn't measure shim thickness.
                    • 15609
                    Originally posted by Larry Mulder (20401)
                    Gary:
                    Larry
                    One of the stranger AIM issues. The holes in the frame for the cotter pin began to appear during the 1969 model year, but the factory didn't begin to use slotted shims, with the cotter pin to hold them in, until the last week of 1970 production -- end of July 1970. Go figure.
                    BTW: The cotter pin passes through both sides of the frame pocket and through holes int eh slotted shims designed for just that purpose.
                    • Steve L.
                      • June 30, 2001
                      • 763
                      They probably had 100,000 old shims in stock that they wanted to use up.
                      Steve L
                      73 coupe since new
                      Capital Corvette Club
                      Ottawa, Canada
                        Here's the trailing arm shim cotter pin - it's at about 5 o'clock from the end of the pivot bolt, and is 5-3/4" long.
