This car is a 69 435 tripower that I was having some detonation problems with using 93 octane. I have it back together with a thicker SS head gasket but it dies shortly after startup. I switched the center carb off another car and it seems to run pretty good. I took the "faulty" carb apart and everything inside looks good, clean, correct jets, good gaskets, etc. The float level was OK on the engine. I'm hoping it's a faulty power valve.
What is the power valve vacuum value for this carb, this engine? Could it be dumping too much fuel and causing the engine to die?
