1954 Antenna wire. - NCRS Discussion Boards
1954 Antenna wire.
  • Randy G.
    • March 31, 2006
    • 358
    1954 Antenna wire.
    Any good source or recommendations on what to use and where to get one?
    Thanks!
  • Fenwick B.
    • December 31, 2004
    • 115
    Re: 1954 Antenna wire.
    I got one from Grossmulers a few years back. http://gccorvettes.com/?action=home
    • Roy B.
      • January 31, 1975
      • 7044
      I installed a repro some years back and the nut end connecting to the trunk the threads were different then the female threads
      • Cathy S.
        • August 31, 2003
        • 293
        I purchased mine from Grossmuellers also and the inner wire diameter was too small
        • Randy G.
          • March 31, 2006
          • 358
          Looks like Grossmueller's seems to be the only place that has anything unless you ant to make one from wire at Radio Shack.
          • Dan D.
            • November 4, 2008
            • 1323
            The latest Corvette Central catalog has 56-62 antenna cables. Don't see it on their on line catalog. New item, and advertised as having the correct die cast serrated nut. Will let you know - I am going to buy one.
            Nothing listed for 53-55 though. -Dan-
            • John S.
              • July 29, 2009
              • 640
              grossmuellers is the only place i could find a antenna wire. nut connecting antenna wire to trunk has incorrect treads, but it was usable. the inner wire is too small and it needs a sleeve over the wire to fit correctly. the inner wire has a coating on it that should be removed before installing on trunk fitting.
              • Randy G.
                • March 31, 2006
                • 358
                I guess I should post a follow up.
                John is right about the incorrect threads. I had one that came with the car that I believe came from Grossmueller's a long time ago but can't swear to it.
                Anyway, 6 volt Wonderbar reception is great and it works like a champ.
                Randy
