Trailing arm rebuild source in Ohio area..or close by.. - NCRS Discussion Boards
  • James H.
    • February 22, 2007
    • 130
    I was installing my rallies today on the 67 and during installation I notices the pass rear bearing has excessive play so out it came. Not too bad, 2hrs later its ready to be shipped out. I live in the Toledo area and am currious if you all know of a reliable source to handle my job.
    Jim
  • Dick W.
    • 10483
    Re: Trailing arm rebuild source in Ohio area..or close by..
    Bairs Corvette in PA would be a good bet. They do excellent work. Google them.
    Dick Whittington
    • Michael M.
      • November 1, 2004
      • 64
      James,
      Earl Smith in Sandusky did mine 5 years ago and am very satisfied.
      Mike(42753)
      • David S.
        • August 9, 2009
        • 595
        Bairs does great work.
        -Dave
        • Paul B.
          • April 30, 1995
          • 482
          Bair's have done 6 of my 8 trailing arms and they have been GREAT!!! Many, many miles with zero issues!!!
          • Mike G.
            • July 31, 2002
            • 709
            bairs does all of mine. they are as close as the nearest ups store. call brian at 1-800-421-9644. they do great work and you get it back ready to install.
            • Wayne P.
              • January 23, 2008
              • 444
              Bairs did mine Brian gives excellent service
              • Steven S.
                • August 29, 2007
                • 571
                I would also suggest Gary Ramadei, he is a member here and I'm sure will treat you right.
                • Larry M.
                  • January 1, 1992
                  • 2700
                  Agree with the others above: use Bairs or GaryR. Both are top-notch.
                  Bairs did mine back in January.
                  Larry
                  • Michael F.
                    • June 4, 2009
                    • 291
                    Just got mine back from Bairs today. They are a text book case of an efficient,courteous,professional business and the work was done right!
                    • Jim T.
                      • March 1, 1993
                      • 5351
                      Jim
                      James one rebuild feature you will get from Bairs is the rotor/disc riveted to the spindle and trued just like your 67 left the factory with.
                      The great thing about this service is that your 67's disc will not be contributing to bleeding of the caliper to get air out of it.
                      • Larry M.
                        • January 1, 1992
                        • 2700
                        Agree.
                        However, GaryR drills and countersinks the rotor and uses special screws/bolts that hold things securely, and can also be removed later to service the parking brake shoes, etc. Very nice!! And his run-out numbers are second to none.
                        Again, both are outstanding rebuilders.....you can't go wrong.
                        Larry
                        • James H.
                          • February 22, 2007
                          • 130
                          Well I'm giving my local guy a shot. Earl Smith aka "Smitty" has been working on vettes for a long time and has done many arms. Cureous though, how much have you paid for your rebuilds?
                          Thanks all,
                          Jim
                          • Steven B.
                            • June 30, 1982
                            • 3996
                            Don't know Gary's fees but Bair's;
                            .1965-82 Rebuilt Rear Suspension
                            Matching numbers & top quality work are important to your Corvette
                            Choose Bair's to protect your investment
                            We will professionally rebuild YOUR rear trailing arm to TOP QUALITY
                            PARTS:
                            1 Inner Bearing
                            1 Outer Bearing
                            1 Inner Race
                            1 Outer Race
                            1 Shim & Spacer
                            1 Inner Seal
                            1 Outer Seal
                            1 Inner Dust Shield
                            1 Castle Nut & Washer
                            1 Handbrake Cable Guide
                            1 Handbrake Adjuster
                            1 Set S.S. Handbrake Springs
                            1 Anchor Bolt Lock
                            1 Backing Shield
                            2 Handbrake Shoes
                            2 Handbrake Levers
                            5 Wheel Studs
                            5 Rotor Rivets
                            1 Front Trailing Arm Bushing Kit
                            4 Trailing Arm Studs & Nuts
                            $349.00
                            814-683-4223
                            ORDER LINE ONLY 800-421-9644
                            3 YEAR GUARANTEE
                            Unlimited Mileage
                            LABOR
                            Complete Inspection of all Parts
                            Clean & Detail Parts
                            Check over 30 Spot Welds on Trailing Arm
                            Rebuild Trailing Arm
                            Set Up Bearings to GM Specs
                            Assemble Handbrake Hardware
                            Check Spindle Support (each year is different)
                            Recondition Spindle Support
                            Recondition Spindle Flange
                            Recondition Caliper Support Braket
                            Rivet & Machine Rotor to Match Spindle and Remove Run Out
                            Press Front T-Arm Bushing into Arm
                            Pack Wheel Bearings with High Quality Grease
                            Press Together & Torque to GM Specs
                            Adjust Handbrake
                            Free Custom Built Shipping Boxes
                            MATCHING NUMBERS (DATES)
                            Over -40 Years Experience, Same Location
                            • Michael F.
                              • June 4, 2009
                              • 291
                              If you have a local who really knows how to set up the bearings etc..Go for it. The shipping raises the cost considerably. But I didn't have the time to search a local pro out. I am very happy with Bairs.
