327 - 340 hp owners, I have a question for you - NCRS Discussion Boards
  • Bernard B.
    • May 10, 2010
    • 11
    Is your 340 hp as fast as the 327 - 350 hp ?
    How much slower is it compared to the 365 hp ?
    Bernard
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: 327 - 340 hp owners, I have a question for you
    Have put them both away on numerous occasions, but I give credit mainly to the gearing. Most are equipped with 3.55, 4.11 or 4.56, and they fall for the old "30 on up trick". Add to this, and even more so, are the L-84 fuelies. Oh yes, mine is a 3.36 and the 3.08 L-76's usuially concur.
    Stu Fox
    p.s. was this a trick question, one designed to stir the blood?
    • Terry D.
      • May 31, 1987
      • 2691
      Check the archives, this has been answered before. There is no noticable difference in the three.
      • Bernard B.
        • May 10, 2010
        • 11
        No its not a trick question.
        I am in the process of buying a 327 c2 and I want to make sure I make the right choice.
        How often do you have to change the points ?
        And do it usually remain tuned or do it need constant bay nurturing ?
        Thank you
        Bernard
        Stu Fox
        • Terry D.
          • May 31, 1987
          • 2691
          If you want the least amount of work get a 350, it has a hydraulic camshaft. The point replacement depends on how much you drive. If you are looking for a car that you never have to work on maybe you should consider a new car that has a warranty.
          • Joel T.
            • April 30, 2005
            • 765
            Bernard
            Bernard;
            I have a 1963 340 coupe, close ratio T10 4 speed 3.70 posi rear... The car is quick off the line, a little quicker in my estimation than my 1965 BB... to a point. Having said this you could buy a Honda Accord and get just as good if not better zero to 60 times... check out the numbers.
            As someone said the level of maintenance is related to how much you drive it... my points, and plugs, have been in there 2 - 3 years now and are working fine... For me, part of the fun of owing the car is maintaining it and getting the looks and "thumbs up" gestures when I drive it to a classic car nite or just down the road on a Sunday afternoon. Makes no difference what engine is in there!
            My advice is to get a car that you like... regardless of the engine... and if going fast is what you are after, look into a leftover 2010 Corvette, there are great deals out there.
            Joel
            • Joel T.
              • April 30, 2005
              • 765
              Stu Fox
              Hi Stu;
              OK, I give up... what is this "30 on up trick"????
              Joel
              • Larry M.
                • January 1, 1992
                • 2691
                Originally posted by Joel Talka (43778)
                Hi Stu;
                Joel
                Most likely starting the "contest" from a 30 mph rolling start. Didn't require a stoplight, and was easier on the tires.
                Larry
                • Stuart F.
                  • August 31, 1996
                  • 4676
                  Bernard;
                  FWIW: I installed electronic ignition many years ago so points are not a consideration now. Before that, they were a constant maintenance item along with the plugs (which are not easy to change). My current plugs are Champions that I put in about 7000 miles (6 years) ago and I have no trouble making redline with them. I adjust the valves about every other year, or when I feel ambitious. After some extensive effort, I finally have the ethanol laced gas problem under control (hot soak percolation and stumble) which, I believe was one made simpler by the fact that the AFB is easier to work with than the Holley's (my opinion).
                  Joel; "30 on up" refers to when one of your friends wants to "mix wheels" and you say "fine, but I'm geared high so lets do a rolling start from 30mph on up". They are so anxious to get it on that they agree to it - to their downfall. It's the most fun against guys with the 4.56's or 4.11's when they run out of gear and you motor away - usually on the other side of 100 mph. You will usually be side by side until then too to make it more interesting. This is not a game for the faint at heart, and not advised for anyone over 70, like yours truly.
                  Stu Fox
                  • Michael W.
                    • April 1, 1997
                    • 4290
                    Thank you
                    Bernard
                    If these cars were driven daily as they were when new, it might need points or a dwell adjustment once a year, maybe twice. If we still used leaded gas, it might need new plugs also once a year.
                    With unleaded gas (best thing ever invented for engines) and the relative little use we give the cars today, you'll be opening the hood because you want to, not because you have to.
                    On the chance that you're from Quebec or Eastern Ontario:
                    www.ncrsquebec.com
                    • Joe C.
                      • August 31, 1999
                      • 4598
                      Bernard
                      If a comparably geared 327/365 is done "right", it will put 427 and 454 Corvettes "on the trailer" every time.
                      If a comparably geared 327/350 or a 327/340 is done "right", it will not.
                      • Gene M.
                        • April 1, 1985
                        • 4232
                        A blueprinted with head message 300 horse, on the street stop lite to stop lite will pretty much eat up the 350, 365 and FI given standard 3.36 to 3.70 gears 4 speed and regular size street tires.
                        Now if the higher horse engines were given the same engine treatment all bets are off.
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          1964 365 HP engines were available with the GM TI ignition. my 64 had it.
                          • Stuart F.
                            • August 31, 1996
                            • 4676
                            In comment to Joe's well stated observation; I made many a 327 365 hp "my trailer", but I never had the pleasure of meeting any 350 hp's, or for that matter, any 427's or 454's. My crazy days ended before they were available as I was in SEA during most of that time. When I did return, I was married w/family and that tends to slow you down.
                            Stu Fox
