66 427 underhood drippers? Install? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 942
    Can someone post a picture of the underhood drippers the attach to the bottom of the hood grille opening on 1965/1966 big block hoods?
    I have installed mine and they do not look proper, hope someone can post a picture.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 66 427 underhood drippers? Install?
    Here's 3 pics; one of RH shield on my late 396 ['66 427 is same]. The other views are of the RH shield before installation, side facing outside grille, showing dum-dum sealant. The forward end lower corner in pic 2 tucks under the hood reinforcement X-brace. Pic 3 is the rearward end of same shield. The attaching screws are chrome-plated Phillips, with star washers, in my case. Typical might be different for other production timeframes.
    Hope this helps.
    • William B.
      • April 30, 1975
      • 942
      Thank you mine must be installed wrong, I am going to use your pics as a refference. Thanks again, Bill
