Anyone going to Carlisle who would look for me a part? - NCRS Discussion Boards
  • Jim F.
    • April 7, 2008
    • 60
    Can't find this part anywhere. My windshield washer reservoir drains through my headlight washers. I am told there is a anti-drip valve located behind the headlights that stops this. Plastic barrel like valve/tee. Water comes in, splits to top of headlight and bottom of headlight. If you could find me one at Carlisle I would be glad to pay. Contact me at fox2x2@aol.com for more details or suggestions on how to fix. Will try to attach pic.
  • Pat M.
    • April 1, 2006
    • 1582
    Re: Anyone going to Carlisle who would look for me a part?
    Jim, you certainly need the check valves but also make sure the umbrella valves in the washer pump are pliable and are doing their part to prevent excessive drainage.
    I had a similar problem getting ready for PV and thought my check valves must be bad so I found a couple extra and changed them - yet the problem remained. Eventually I looked at my umbrella valves and realized they were stiff, I changed them, and the problem went away.
    In my experience the check valves and the umbrella valves do a marginal job by themselves, but work well together when both are in good shape.
    Good luck
