1988 engine oil pan - NCRS Discussion Boards
1988 engine oil pan
  • Dan A.
    • May 31, 1974
    • 1073
    1988 engine oil pan
    GM Canada does not service this part. Is it availabe in the U.S.?
    Does not appear to be available in the aftermarket as well.
    Is used the only option?
  • Pat M.
    • April 1, 2006
    • 1579
    Re: 1988 engine oil pan
    I'll give your post a bump Daniel, someone should be able to help.
    • William C.
      • May 31, 1975
      • 6037
      88 & 89 were the same, P/N 10055765, but P/N may have changed. GM Parts Cheap.com says they have availability but wouldn't give me a part number online, might be worth checking if you haven't tried already.
      Bill Clupper #618
        • 43247
        Bill and Dan------
        GM #10055765 is the last available part number I show and it's discontinued. There may be a replacement part number I can't find, though. I doubt it but it's possible.
        I THINK the 92-96 LT1 pan would work except that it has a fitting for an oil level sensor. Unfortunately, it's discontinued, too.
