C2 Antenna Cable Replacement - NCRS Discussion Boards
  • John L.
    • 102
    I am in the process of replacing the antenna cable in my '66 coupe and started the work last night, it is amazing what you uncover when you start these projects. Took off the sill plate, pulled back the carpet and:
    1) the current antenna cable is a replacement and just runs under the carpet, not under the wire floor cover under the sill plate; 2) the original cable is still under the wire floor cover and has been cut upfront by the fuse box and at the rear of the car before it enters the grommet; 3) it appears the wire floor cover has never been removed, the tabs are rusty and likely can not be removed without destroying it (I will let it be); 4) by the rear wheel hub, someone spliced into the rear harness with a red/brown colored double wire spliced into the yellow colored harness wire and a single green wire spliced into the brown wire. However, the end of each of these wires are cut and lead to nowhere; 5) the replacement cable is routed though the same hole in the rear grommet as the wire harness. Getting that grommet out is will not be easy.
    Any thoughts as to why someone would splice into the rear harness? Thanks for your comments.
  • Norm B.
    • 360
    Re: C2 Antenna Cable Replacement
    R: 4)
    Just a shot in the dark without knowing what those wires provide power to but I am guessing that Bubba was towing a trailer and needed lights. Any evidence of a trailer hitch in the past?
    Norm
    Golf is for those who can't play​ hockey.
    • Michael J.
      • January 27, 2009
      • 7145
      You're lucky, on mine Bubba ran the replacement throught the firewall, through the strap for the positive battery cable, under the car along the tunnel, and over the differential housing to the rear. Easy to remove and replace, but what a mess.
      • Thomas C.
        • August 31, 2000
        • 133
        Hey John, I recently had to replace the ant cable in my 67. While I was there I decided to replace the rear harness as well. I bought a new grommet which was a must.. My wire cover came off with a little persuasion. Let me know if you need a hand. Tom
        • Richard J.
          • February 18, 2010
          • 46
          My Bubba was worst than your Bubba... Mine ran the cable from the antenna, completely under the body of the car and came back into the passenger compartment through the floorboard hole on the passenger side.
          Needless to say, mine runs where it belongs now..
