1967 power brakes - NCRS Discussion Boards
1967 power brakes
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11332
    Re: 1967 power brakes
    Repeating previous post. it won't save my edits!
    Jerry, What engine? C60 or not?
    Likely if only one other small nipple fitting, the hose to VAC. Could be through a pipe to another hose to VAC(as on BB). edit ... see UPC 6 C2 for base. Shows a VAC hose to pipe to carb. L79 I'm not sure the UPC sheet shows nothing, but it must goeto VAC somehow.
    If 2 fittings, other would go to the AC system(iirc, heater valve)
    • Gerald C.
      • June 30, 1987
      • 1299
      Rich,
      My engine is an L79. After a bit more research on this, it looks like the fitting on the intake manifold has just one fitting for the PB booster vacuum hose. I think I'm correct here!
      Jerry
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11332
        #18
        Jerry how is the VAC connected?
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11332
          #19
          I found this photo of a '66 L79, which came to me this way(misc configurations atypical). Is your VAC hose connected directly to the lower front carb nipple? Or is there a pipe between them? I think it should be a pipe.
          Rich
          • Gerald C.
            • June 30, 1987
            • 1299
            #20
            Another question....I see in the LICC catalogue that the front brake line block is the same on the standard and PB cars. Is that correct for the 67?
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11332
              #21
              Jerry, Answer my ?'s in the last 2 posts I asked you about so I don't get 3 strikes, and I'll answer your last ?
              lol
              Rich
              PS.... Yes
              • Gerald C.
                • June 30, 1987
                • 1299
                #22
                Sorry for not getting back to you on this. My vacuum advance tube is connected to the front right of the carb.
                • Gerald C.
                  • June 30, 1987
                  • 1299
                  #23
                  Thanks Rich. My current M/C was a replacement, so I had to buy a correct one to make this work!
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11332
                    #24
                    Ok, Thanks.
                    So carb port must be manifold vacuum, I guess?
                    You'll have to run the new longer brake line from that left rear brass brake junction block to the MC port. It may take some finagleing(sp? lol). You need the car on a lift to wiggle it into position through the chassis center crossmember, bend a bit then straighten. That front clamp bolt is tricky to get out and in, but if you cut the bolt shorter you can squeeze it in there to reinstall, see earlier photos in this thread. Note the thin wrench helps too.
                    And don't forget that little clamp to hold th F & R lines on them as they come up vertically to the MC.
                    One other thing I just thought of too....
                    Make sure your MC to Bosster rod isn't too long. If it is, and upon assembly, pushes MC piston, it could cause brakes to hang up. You want it so it's close, not touching the MC piston. You could grind the rod a bit, or add a gasket or two between MC & Booster. You could cut their perimeter edges to hide them for judging.... Ooops, did I let the cat outa' the bag?
                    Rich
