Wiper Door Limit Switch Plug - NCRS Discussion Boards
  • William C.
    • May 31, 1975
    • 6037
    Re: Wiper Door Limit Switch Plug
    That's a tough deal as the connectors were actually molded on over the wires/terminals. Easiest replacement might be to get the connection (both sides if needed) out of a junked car and splice the wires in an unseen area of the harness.
    Bill Clupper #618
    • Dan A.
      • February 1, 2004
      • 212
      You are probably right, as I have had no luck finding the parts at the usual places. This might be a project that gets put on the back burner for awhile. The wipers are working, but you have to raise and lower the door with the switch under the steering column to avoid the door closing too soon. I am going to replace the switch under the right wiper arm to see if that helps as it had been bypassed.
      Thanks to everyone that has responded. I am always amazed at the depth of knowledge available here. I wish I could reciprocate!
      • Roger O.
        • September 7, 2009
        • 209
        #18
        The under arm switch will help with the parking of the wipers but I would guess if you use the dash switch only the wipers will crash into the bottom of the door before it opens. Does it do that now ? If the door is REALLY fast some will work OK.
        • Jerry B.
          • August 31, 1994
          • 416
          #19
          Hello Dan, You May Want To Check Item No. 160461033024. It Could Help!
          • Pat M.
            • April 1, 2006
            • 1575
            #20
            Originally posted by Roger Owsley (50816)
            Here you go,not the best pic but I think you can see it. You can see the 12 gauge wire,a black connector and then the smaller gauge red going in the side of the motor.
            Where this wire goes into my wiper motor there is a little black plug in the hole, while Roger's appears to have none. Should there be a plug?
            • Dan A.
              • February 1, 2004
              • 212
              #21
              Roger - It is pretty quick, and seems to work once. After the door closes via the regular wiper switch it is all over.
              Jerry - Pardon my ignorance, but I am not sure what you are referring to.
              • Roger O.
                • September 7, 2009
                • 209
                #22
                I think you need the other plug.
                • Roger O.
                  • September 7, 2009
                  • 209
                  #23
                  Pat , yours looks good. The one I posted is missing the plug or grommet.
                  • Pat M.
                    • April 1, 2006
                    • 1575
                    #24
                    Thank you Roger.
