C3 Headlight Switch - NCRS Discussion Boards
C3 Headlight Switch
  • Tom L.
    • May 7, 2007
    • 438
    C3 Headlight Switch
    Does anyone have any experience with repop headlight switches? My original has continuity where it should and the vacuum switch works well, but it's a 40 year old component. I had planned on just replacing it, while I have everything apart, to avoid a future headache. But, I remember reading here that one person had a bad experience with a repop. Thanks.
    • 6948
    Re: C3 Headlight Switch
    Tom, I have read some negative stuff on the repro switchs, if the original still works I would possiably clean the old reostat up with some steel wool or a small brush and some metal polish , the internals don't have to many problems that I have seen.
    • Pete B.
      • February 22, 2007
      • 325
      Tom,
      I had to get 3 before I got one that worked. Lectric limited "said" that they sell 75 of these a year and have no problems....maybe just my luck. I could not bring mine back as the reostat wire was broke.
      The switch was $34 so not too bad considering how much time to replace it later on. I'm glad I replaced it.
      Pete
      Pete Bergmann
      2005 - 2013 C6 National Teamleader
      • Don L.
        • August 31, 2005
        • 1005
        Like Pete's experience, my original had a failed rheostat. I bought a reproduction switch from Corvette Central and then had to get another one as the first replacement switch was bad. CC gave me no problem, sending a replacement out right away and told me to scrap the defective switch, which I did.
        The second one installed well and has worked for the past 4 years without incident.
        Don Lowe
        NCRS #44382
        Carolinas Chapter
        • Tom L.
          • May 7, 2007
          • 438
          Thanks guys. What was wrong with the defective ones so I know what to look for?
          • Don L.
            • August 31, 2005
            • 1005
            Vacuum didn't work on mine.
            Don Lowe
            NCRS #44382
            Carolinas Chapter
            • Randy C.
              • March 1, 1985
              • 154
              I had to get a replacement as the bezel on my old switch was broken off. My replacement came from Corvette America and it worked. I had a little trouble with the vacuum until I realized that I had it hooked up backwards!
              Randy C.
              • D S.
                • March 1, 2005
                • 1551
                My reproduction switch on my 1970 caused my headlights to "flutter" like wig-wag lights on emergency vehicles. Before I realized it was a defective switch I checked the headlight assemblies and other possible causes. I even quit driving the car at night. After posting my dilemma here on the TDB I narrowed it down to the switch. Before I spent money on another reproduction a friend gave me his original off of his 1969 Corvette and mine now work great. I can't recall where I purchased the reproduction.
                Scott Sims
                Texas Chapter
                • Pete B.
                  • February 22, 2007
                  • 325
                  My two defects on different switches were as follows:
                  1) headlights would go off after 30 seconds, on after a cool off.
                  2) The dash lights would not work.
                  Third was the charm!
                  Pete Bergmann
                  • Greg A.
                    • June 30, 1998
                    • 141
                    Tom, I replaced the original in my '78 about 6-7 years ago, just after they started making the repops because the NOS were gone. I don't recall which vendor provided it, but within a year it had a vacuum leak. I cleaned up the original (the reostat was dirty, causing poor dash light dimming) and re-installed it. It's working great. Goes to show you can't beat an original 32 year old part!
                      • 43246
                      Greg, et al------
                      I just knew there was some reason I bought half a dozen, or so, of the GM switches [none for sale] just after GM discontinued them and there were still some "around". Of course, I didn't know the reason then, but I know it now.
                      • Tom L.
                        • May 7, 2007
                        • 438
                        Why fix it if it's not broken? I suppose I'll clean up the original and see how it goes. Thanks everyone.
                        • Kevin G.
                          • February 1, 2005
                          • 1076
                          Tom,
                          Keep in mind that when you attempt your Duntov/PV, the switch must perform as intended! The dimmer function is sometimes difficult!
                          • Greg A.
                            • June 30, 1998
                            • 141
                            As always, Joe, you are the shrewd buyer!
                            • Richard R.
                              • August 31, 1988
                              • 98
                              Tom I had two bad switches, from two vendors. One would not hold when you pulled the knob out it came out in your hand. (made in China). The other one would not dim the dash lights correctly. I finally bought a switch at a swap meet (used but good) and it solved my problem. I won't say who the vendors were but they ars highly rated by everone.
