radiator cap '65 - NCRS Discussion Boards
radiator cap '65
  • Twan B.
    • June 30, 2005
    • 212
    radiator cap '65
    Is my radiator cap from my expantion tank original for my '65 327/300 Hp no air.
    If it's not, what car does it belong to.
    Twan #44079
  • Donald T.
    • September 30, 2002
    • 1319
    Re: radiator cap '65
    It's definitely not an original cap for a 65 Vette. Not sure of the origin.
    • Peter L.
      • May 31, 1983
      • 1930
      Twan - The radiator pressure cap as pictured is a newer AC RC15/15LB cap. The original cap on your 65 would have been an AC 307/13LB cap and been a zinc plated steel cap with larger "ears," not a STAINLESS cap with the smaller "ears." The cap should function OK on your car as all the small block Corvettes went to a 15LB cap in 1966 although it was a RC26/15LB cap and had aluminum components under the cap. There is a newer version of the RC26/15LB cap that is STAINLESS like the STAINLESS RC15/15LB cap you have and as far as I know the only differences between the STAINLESS RC26/15LB cap and the STAINLESS RC15/15LB cap is the stamping in the right-hand circle on the cover. Pete
        What you have is a typical GM service replacement cap (SS with the 'Inspect Spring & Fall emboss)...
