'93 parts help - NCRS Discussion Boards
'93 parts help
  • John G.
    • January 1, 2006
    • 85
    '93 parts help
    call me crazy!!!just finishing my 61 and a friend calls with a 93 coupe he was going to buy and burn the body off...for parts he builds street rods. well the body is perfect aqua metallic coupe 207,000 miles. i couldn't let him do it so i bought it. the engine (original) has stacked bearings....will rebuild same..my question what is th e parts no's for the air bleed pipe assembly (was cut in half) when the heads were removed and wherwe can i find those parts.
    thanks in advance,
    john
  • Ed H.
    • November 1, 1999
    • 626
    Re: '93 parts help
    If you are talking about the secondary air injection pipe, in the LT-1 motor, that attaches to the rear of the throttle body, and then into the right hand exhaust header. Let me know if that is the hose you are referring to.
    • Larry H.
      • May 31, 1994
      • 63
      Re: '93 parts help
      John,
      I think you are looking for #10108636, which is the air bleeder pipe that runs from head to head. Unfortunately it has not been available from GM since 2003.
      Larry
      • John G.
        • January 1, 2006
        • 85
        Re: '93 parts help
        yes, it runs between the back of the heads (banjo fittings) then to a hose off the coolant fill tank. i've got a camaro engine with this pipe but it routes along the intake instead of straight to tank.
        john g.
        • Ed H.
          • November 1, 1999
          • 626
          Re: '93 parts help
          John,
          Those type of parts are almost non-available. Try the Corvette Forum under C-4 Parts. Or try Whites Racing LLC in Florida, (813)264-8353. I have found a lot of obscure parts for my 93 ZR-1. Good luck.
          • Larry H.
            • May 31, 1994
            • 63
            Re: '93 parts help
            John,
            You may be in luck. I was just on Keen Parts website and they list a reproduction of the #10108636 pipe.
            Larry
              • 43247
              Re: '93 parts help
              Originally posted by Larry Hardesty (24649)
              John,
              Larry
              Larry------
              I'm really glad that Keen has reproduced the 10108636. This is a part that folks are going to be needing primarily due to corrosion damage and, as you mentioned, it's long-since GM-discontinued. The special seals, GM #10108689 are still available, though.
              • John G.
                • January 1, 2006
                • 85
                Re: '93 parts help
                Thanks to all for the input. Hope I can return the favor....will contact Keen on Monday.
                John G
