67 Under Dashboard Wiring Harness Mounts - NCRS Discussion Boards
  • Ira L.
    • May 31, 2006
    • 32
    Can anyone either explain or have pictures as to where the 2 wiring harnesses under the dashboard get mounted. The two harnesses, one for the TS off the column and the other one I believe off of the fuse box both have clips on them but I can's find where they clip onto.
    Ira Lippel
    45858
  • Stephen L.
    • May 31, 1984
    • 3161
    Re: 67 Under Dashboard Wiring Harness Mounts
    The turn signal switch wiring clips to the left side of the pedal bracket on a lip close to the firewall, after it twists around the column. Check out this thread for photos.
    https://www.forums.ncrs.org/showthre...65186&uid=8211
    Check out you AIM as it shows how to route the various wiring under the dash and where the clips go.
    • Ira L.
      • May 31, 2006
      • 32
      Thanks Stephen, I'll check both sources.
      Ira
      Ira Lippel
      45858
