1968 Parts Needed - NCRS Discussion Boards
1968 Parts Needed
    • February 13, 2009
    • 16
    1968 Parts Needed
    I'm looking for the following correct date coded parts for a 1968 427/390:
    1) Carb
    2) Starter
    3) Alternator
    4) Smog Pump
  • Scott S.
    • September 11, 2009
    • 1961
    Re: 1968 Parts Needed
    Hi Alan,
    I would recommend John Pirkle first for the correct starter motor and alternator:
    • Terry B.
      • August 31, 1999
      • 607
      Alan,
      Call Bill Hodel, (330) 832-0871, for all your smog pump needs.
      Terry Buchanan
      Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
      Corvettes Owned:
      1977 Coupe
      1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
      2003 Electron Blue Coupe
      2019 Torch Red Grand Sport Coupe
        • February 13, 2009
        • 16
        Thanks for the info Scott & Terry!
        • Jim T.
          • March 1, 1993
          • 5351
          1) Carb
          2) Starter
          3) Alternator
          4) Smog Pump
          On my original owner 68 I replaced the original air pump with a rebuilt unit from Auto Zone a couple years ago. The rebuilt pump from Auto Zone was an exact replacement except for the plastic filter at the front of the pump. I did not turn in my original pump, it will be available for the next owner if he wants to have it rebuilt. The correct valve that attaches to the pump will not be an easy find. I replaced my original valve in 1974 from GM and the person at the parts counter told me one like the original was not available and sold me another valve that would work. Different part number and the air muffler is different. It still works.
          • Mark J.
            • November 1, 1998
            • 57
            1) Carb
            2) Starter
            3) Alternator
            4) Smog Pump
            To purchase or borrow? (Just kidding, sort of..)
            What date are you looking for?
            carb, 4 spd or automatic?
            I don't have any of the above on my car.
              • February 13, 2009
              • 16
              Early 68, Automatic trans
              • Terry B.
                • August 31, 1999
                • 607
                Alan,
                My '68 is also the L-36 with an automatic transmission. The most expensive parts on your list would be a complete smog system, if you need it. Second would be the carb. Being an early car, there aren't many out there to find that are L-36 with auto. My car is a Dec '67 build and was difficult but I found one. The starter and alternator should be able to be supplied through John Prikle who does outstanding work.
                The part that took the longest for me to find (7 years) were the "correct" front grills. They are prone to break and are not in reproduction. What you will see on most '68's are the '69 style grill.
                Good luck and let me know if I can help with the search.
                Terry Buchanan
                Corvettes Owned:
                1977 Coupe
