72 Fan Clutch - NCRS Discussion Boards
72 Fan Clutch
    • 6948
    72 Fan Clutch
    Is the fan clutch on my 72 painted dull silver or is it natural aluminum, any ideas. Thanks, Ed
  • Bill C.
    • July 15, 2007
    • 904
    Re: 72 Fan Clutch
    Ed,
    I'm pretty sure the clutch unit is natural aluminum finish. The only part that was painted silver is the steel mounting shaft/hub part.
    • Michael G.
      • March 2, 2008
      • 485
      Re: 72 Fan Clutch
      Yes Ed, It is a natural cast aluminum finish. I'm not sure what the bi-metal plate on front was originally. Mike
        • 6948
        Re: 72 Fan Clutch
        Thanks guys, I did have some aluminum finish left on the flange and the rest looked natural but was not sure. I am just cleaning up the original.
          • 6948
          Re: 72 Fan Clutch
          I don't know if any one has there original fan clutch, but I found what I believe to be some red colored dye on the side facing the engine, Bill or Mike ?Or someone else.
          • Bill C.
            • July 15, 2007
            • 904
            Re: 72 Fan Clutch
            mine is and there a red/orange dot (size of a BB) on the outer edge.
            I think it may have been for balancing or alignment....
            mine is on the side facing the radiator.....
              • 43246
              Re: 72 Fan Clutch
              Edward------
              Attached are photos of an NOS GM #3991426. I believe that all GM #3991426 were manufactured by Sweitzer Clutch. However, it's possible that some were manufactured by Eaton. The clutch pictured has a natural finish on all of the aluminum components. The bi-mtallic strip is natural finish with ink stamping and the strip retainer is natural steel. The exposed shaft, the forward and side faces of the hub were painted with aluminum paint. The rear face of the hub (mates to face of pulley) was unpainted.
                Re: 72 Fan Clutch
                Check your copy of the '72 AIM. You should find drawing detail regarding marks on the fan clutch and matching marks on the water pump hub (balance/alignment) that appeared in '72 and weren't detailed in '71...
                  • 6948
                  Re: 72 Fan Clutch
                  Jack , Thanks for the input, there was a blue mark on water pump and a yellow dash on fan clutch for alignment. I did happen to find a red dot on the front clutch face and red dye looked to be sprayed on the side facing engine. and some dull aluminum spary on the hub. do you thing that there was some overspray on the aluminum from painting the hub? it appears that a found some on the aluminum.
                    Re: 72 Fan Clutch
                    I wouldn't doubt there were certain Schwitzer clutches with some random overspray from painting the input shaft/hub. But, then I don't know the assy order that was used at Schwitzer (was shaft/hub embossed and painted before or after assy?)...
                    • Bill C.
                      • July 15, 2007
                      • 904
                      Re: 72 Fan Clutch
                      I would be willing to bet the shaft was painted after final assembly.
                      I did a light degreasing on my unit and I noticed aluminum overspray on the bearing/seal. Must have been one assembly when painted.
                      I can grab some pictures Thursday whne I get back home.
                        • 6948
                        Re: 72 Fan Clutch
                        Bill, if I would have just read Joe L. post a little more closely, his post states there was some overspray of the aluminum surface.
