Master Cylinder leaking - NCRS Discussion Boards
  • Edward C.
    • August 31, 1993
    • 27
    I understand there is an aircraft sealer that works well on a seaping front connection of an 022 master cylinder. Is this the best solution and where can I find some?
    Re: Master Cylinder leaking
    Ed -
    If the connection has been disturbed, a fresh pair of soft copper washers should cure it correctly.
