How to know if my car really is no radio? - NCRS Discussion Boards
  • Alexander C.
    • June 20, 2010
    • 353
    I was told by Coast Corvette that my '56 is most likely a no radio option car. It has a radio from a 1957 and he said the antenna was wrong. It does have a hole in the rear fender that the antenna is not going through at the moment.
    As I am far from expert with this being my first Corvette, what little tell tale signs would there be that the radio was added later? Maybe the size/shape/location of the antenna hole? Maybe wiring under the dash? Antenna brackets in the rear trunk?
    I know this will be difficult to do online but I'm hoping to resolve it because I would like to sell the radio.
    Thanks!
    Alex
  • James G.
    • May 31, 1976
    • 1556
    Re: How to know if my car really is no radio?
    Thanks!
    Alex
    1956 WONERDBAR radio had a blank tuning bar. the word WONDERBAR is on the 1957 tuning bar. The radios were also made for passenger cars (and Cadiliac), but the receivers were different. Look under the dash. There should be a receiver (with tube and transformer etc.) behind the speaker with a connector going to the additional receiver behind the radio itself. Only Corvette had both receivers. Passenger cars had just the one receiver behind the radio.
    I am interested in the radio if you want to sell it, depending on what it is, so send me a PM.
    • Alexander C.
      • June 20, 2010
      • 353
      Ok. Like I said it is a 57 radio with the word wonderbar on it.
      I'll get under there and look for the receivers. I will be selling it either way as I either need a '56 correct radio or just the cash lol.
      Thanks!
      Alex
      • Roy B.
        • February 1, 1975
        • 7044
        Look under the fender , if it dont show a hole repair where it should be then it's a non- radio.
        • James G.
          • May 31, 1976
          • 1556
          Thanks!
          Alex
          Lot less money to change the station bar to plain vs. buying a new radio. Let me know please.
          • James G.
            • May 31, 1976
            • 1556
            Left rear fender. In the trunk. Open and look close.
            • Alexander C.
              • June 20, 2010
              • 353
              Ok wait. So if it's a no radio, then it would have a factory hole repair there? That won't work for me since the hole is there and is open lol.
              • Roy B.
                • February 1, 1975
                • 7044
                Why then if it has a hole in the fender? (in the correct location)
                • Alexander C.
                  • June 20, 2010
                  • 353
                  Well I guess I don't know yet if it's the correct location. I'll have to check still.
                  Anyone can add one though right? Wouldn't that explain it? That's why I'm trying to find more clues...
                  • Steve H.
                    • November 1, 1996
                    • 118
                    Alexander,
                    The only sure way I know (short of having the paperwork on the car) is the absence of a hole on the left rear fender just forward of the tail light assembly. All other radio related items can be removed or added without tale tale signs.
                    Steve
                    • Edward L.
                      • 278
                      [quote=Alexander Claytor (51884);501052]I was told by Coast Corvette that my '56 is most likely a no radio option car. It has a radio from a 1957 and he said the antenna was wrong. It does have a hole in the rear fender that the antenna is not going through at the moment.
                      Thanks!
                      Alex[/quote
                      The attenna hole should be located 4 inches from its center to the chrome lip of the tail light housing.
                      You state that the antenna hole is not being used currently, where then is the antenna mounted? The original cable and taillight harness was installed before the left rear quarter panel was glued in place and ran through the rocker panel. If there is no evidence of a cable ever having been n the left upper part of the trunk, nor behind the front kick panel, it was probably a no radio car. No one would have attempted to run a cable through its original correct location whether the cable was being replaced or added. The job is a nightmare at best.
                      Ed
                      • Bruce B.
                        • May 31, 1996
                        • 2930
                        Does the car have any of the radio or ignition shielding or brackets?
                        A radio delete car did not have these.
                        • Barry H.
                          • April 30, 1976
                          • 213
                          Bruce & Alexander, 56 & 57 radio delete cars HAD all the ignition wire brackets. Just no shielding. Barry Holmes
                          • Alexander C.
                            • June 20, 2010
                            • 353
                            No shielding.
                            • Alexander C.
                              • June 20, 2010
                              • 353
                              Ed
                              Perfect! Great info! I'll check to see how it's run.
                              Right now the antenna is laying in the trunk attached to the signal cable.
