68 Fan - NCRS Discussion Boards
68 Fan
+ More Options
Posts
  • Dan M.
    • March 6, 2009
    • 157
    68 Fan
    Car: 68 327/300 with 4 speed. No A/C Has Power steering
    Question: What fan came on this car from the factory? 5 blade or 7???
    What part number fan? I searched prior posts but its not clear for 68.
  • Roger O.
    • September 7, 2009
    • 209
    Re: 68 Fan
    My book shows 3955182 for 68-70 , 7 blade , 17 1/2"..... $27.75
    I would have bet $50 it would have been a 5 blade.
    Better wait for the more knowledgeable 68 guys before you order !!!
    • David L.
      • July 31, 1980
      • 3310
      Re: 68 Fan
      The 3955182 fan did not exist in 1968.
      The fan used on the 1968-1970 Corvettes and 1966-67 Corvettes (427) is GM # 3888366, 17 1/2", 5 blades, 3" bolt circle. It is made by the Hayes-Albion company and has the following stampings: "H", FRONT", and "66". The "66" stamping is the middle 2 digits of the 6-digit Hayes-Albion part number, not the GM part number.
      GM # 3888366 was replaced by GM # 3955182 in April 1971 as per Chevrolet Parts History.
      • Dan M.
        • March 6, 2009
        • 157
        Re: 68 Fan
        Thanks David
        • Roger O.
          • September 7, 2009
          • 209
          Re: 68 Fan
          Guess I wouldn't have lost my 50 bucks after all.
            • 43290
            Re: 68 Fan
            David-----
            Just one slight correction. While the 3955182 was not used in PRODUCTION for 1968 or earlier, it was used in PRODUCTION for some 1969-70 Corvettes. These included L-46 small blocks with C-60, some or all 1969 big blocks with C-60, and, possibly, some 69-70 L-46 without C-60.
            • David L.
              • July 31, 1980
              • 3310
              Re: 68 Fan
              Joe,
              I would consider that additional information, not a correction. The original question was about the fan for a 1968 Corvette, not for 1969 and later Corvette fans.
              Dave
              • Dan M.
                • March 6, 2009
                • 157
                Re: 68 Fan
                Correct. I was looking for info specifically for the 1968 327/300.
                Thanks again David!
                  • 43290
                  Re: 68 Fan
                  Joe,
                  Dave
                  David------
                  The reason that I used the term "slight correction" is that you said:
                  "The fan used on the 1968-1970 Corvettes and 1966-67 Corvettes (427) is GM # 3888366...".
                  I interpreted this as your saying the 3888366 was the fan used for all 1968-70 Corvettes which, of course, is not the case. If I interpreted you incorrectly, my apologies and, in that case consider the information I provided as "additional information".
                  Also, I completely understand that the original question related only to 1968 Corvettes. So, if you had said the GM #3888366 fan was the fan used for all 1968 Corvettes that would have been 100% correct. However, your response included additional information beyond the 1968 model year and that's what I was commenting on.
                  • David L.
                    • July 31, 1980
                    • 3310
                    Re: 68 Fan
                    Joe,
                    You are correct. It was a mistake on my part, I apologize. I guess I had a "senior moment".
                    My statement should have been that the fan used on the 1968-1970 Corvettes (exc. A.C.) and 1966-1967 Corvettes (427) is GM 3888366.
                    The 1968 Chevrolet Parts Catalog (Oct. 1967) lists the 3789562 fan (18" dia., 5-blade) for 1968 Corvettes w/AC as well as other models.
                    The 1969 Chevrolet Parts Catalog (Oct. 1968) lists the 3955182 fan (17.5", 7-blade) for 1969 Corvettes (427 w/AC)(exc. 3 X 2).
                    The 1968 Corvette Assembly Manual lists only the fan-clutch used with the C60 option (AC) as the same fan-clutch used with the L36 option (GM # 3937771). The L88 also uses this same 3937771 fan-clutch. There is no reference to the fan part number.
                    After doing this minor research it is now not really clear to me which fan was used on the 1968 Corvette w/C60, L36, or L88 options. I had always thought that it was the production fan, GM 3888366, but now I have doubts.
                    Dave
                      • 43290
                      Re: 68 Fan
                      Joe,
                      Dave
                      Dave-----
                      If the 3789562 was used at all for 1968 Corvettes, I think it would have only have occurred for early 1968 Corvettes with A/C. So far, though, I've yet to see a documented case of this fan being originally installed on a 1968 Corvette. Of course, that does not mean that it never happened.
                      The P&A Catalogs indicate that the 3955182 was used for 1969-70 L-46 with C-60 applications as well as 1969 L-36 with C-60. There are definitely many documented cases of the original use of the 3955182 for 1969-70 L-46 with C-60. If I recall correctly, there are also documented cases of the use of the 3955182 for some non-C-60 L-46 cars.
