Some help w/ '57 rear axle code - NCRS Discussion Boards
  • Garry E.
    • September 30, 2002
    • 240
    I have question regarding the casting number and date code on the rear axle of my '57...... I finally removed enough grease/dirt from the unit to read the numbers.....
    This is what I have..... Casting# - 3789812; Date Code - K 1 6..... Over the top of the GM casting mark is what appears to be a "6" cast into the surface.....
    There is also a small drilled "hole" in the top of the left axle shaft carrier.... is this some type of vent? I thought only POSI TRAC rear ends had such vents....?
    I wonder if I have a "56" rear end in this car..... It would seem a bit strange since the car was assembled on April 4, '57.... Wouldn't this be a bit late to have '56 parts on the car....?
    Any thoughts on this......?
    Garry Eastwood
    #38705
  • Mike M.
    • May 31, 1974
    • 8400
    Re: Some help w/ '57 rear axle code
    differential casting #'s were 3725899 for non-posi and 3743833 for the posi's. i suspect your casting # 812 is out of a pass car. the date of nov 56 would be very unusual for an april 57 vette. there is a hole in the top left of the axle housing regardless of posi or non-posi. if posi, a brass 90 degree elbo threads into the hole with an attached pice of steel tubing. if it was a non posi, the hole accepted a small breather assembly which is common to the pass cars of the 50's . mike
    • Eric V.
      • November 1, 1974
      • 53
      Garry,
      According to Alan Colvin's book Chevrolet By The Numbers covering model years 1960-1964, the 3789812 casting number housing is for late '61 and all '62 Corvettes with posi, and was also used in '62-'64 passenger cars with posi. I know on the face of it this does not jibe with your date code of K 1 6, but perhaps the housing is a service part purchased in 1966 or 1967. Anyway, it is not a '56 or '57 differential housing. Hope this helps.
      Eric
      • Garry E.
        • 240
        Eric/Mike:
        Thanks for your comments...... It really doesn't surprise me since the car seems to be a composite of a lot of different parts from various years..... The correct rear axle cover (and the internals....) simply become another part to add to my "shopping list".....
        thanks....
        Garry Eastwood
