63 Engine Mount Ground Strap Question - NCRS Discussion Boards
  • Marco H.
    • March 1, 2002
    • 218
    Hello,
    The '63/'64 JG calls for the motor mount ground strap (U69) to be installed on the RH side. (It even shows a picture from the AIM.) The '65 JG calls for the LH side, however the '65 AIM shows it on the RH side. Same for '66. The only AIM showing the strap on the LH side is the '67.
    On '65-'67 I'm used to see the strap on the LH side. However have hardly any experience with '63-'64. (Currently the car has one on each side, which elliminates checking the holes for threads.) Checked the archives with little luck only.
    Any clarification is greatly appreciated.
    Marco
  • Chuck G.
    • May 31, 1982
    • 2036
    Re: 63 Engine Mount Ground Strap Question
    FWIW, my late 63 has ground straps on both sides too.
    Chuck
    • Jon R.
      • February 8, 2010
      • 163
      Also, FWIW, my mid May '63 has ground straps on both sides.
      • Stuart F.
        • August 31, 1996
        • 4676
        My early July car has ground straps on both sides as well - always has.
        Stu Fox
        • Alan D.
          • January 1, 2005
          • 2046
          Mar 64 car has only one on RH side, the LH side has hole however no thread marks (yes is original frame)
          • Michael F.
            • June 4, 2009
            • 291
            My March 63 has both and all the rest too.
            • Marco H.
              • March 1, 2002
              • 218
              Hmmmm....
              Sounds like in my case having both ground straps in place is just the right thing to do. My car is a May production. Thanks everyone for their input.
              Marco
