62 body shims - NCRS Discussion Boards
62 body shims
  • Terry D.
    • May 31, 1987
    • 2691
    62 body shims
    Need a little extra clearance in the tunnel area for a Tremec 5-speed. What is the downside to using extra body shims to achive this? What would be the extreme lift I could get?
  • Doug F.
    • November 1, 1983
    • 322
    Re: 62 body shims
    steering column through the fire wall and bumper braces start to not line up after a 1/2 inch extra shims or so, also unless it's a 61 - 62, exhaust can be an issue, if it's an early car make sure the motor mount stands are as low as possible and drop trans x member as far as possible
