57 hood latches/catch - NCRS Discussion Boards
+ More Options
Posts
  • Chris S.
    • March 28, 2007
    • 139
    my hood keeps poping up on rough roads and i know i have read somewhere about how to fix these. i believe Roy wrote an article but couldn't find it in "search" mode. can someone explain the fix to me. i heard about removing the female latch and grind so you have sharp (not smooth edge) for the male end to fit.
    thanks
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 57 hood latches/catch
    Correct file the female LIP ( they get rounded ) and some times tilt or shim the upper two bolts will help original will have logo
    also ajusting the male stop to keep it from moving
    • Steven B.
      • June 30, 1982
      • 4013
      Chris, I also had a problem with the hood on my '57 popping up on rough surfaces and bumps and have tried Roy's suggestions years ago. They work. I also had worn males. I replaced them with originals from GM (in 1964). Worn parts and alignment will all contribute to the hood popping up.
      Good Luck!
      Steve
      • Roy B.
        • February 1, 1975
        • 7044
        At Bend Or. Next month I've been asked to put on a seminar on how to adjust 53 to 57 hoods on Sat. I'll show how to do it with out drilling or elongating holes, and why GM used pop-ups. At the radiator .I think I covered it on this forum once?
        Hasn't some one done a article in the restorer on the hood adjustment yet
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11364
          I vote Roy should!
          • Randy G.
            • April 1, 2006
            • 358
            Roy:
            I volunteer my '57 for you to "fix" at your seminar as a demo car.
            RG
            • Roy B.
              • February 1, 1975
              • 7044
              Originally posted by Randy Goodwin (45471)
              Roy:
              RG
              RG Thanks but I don't do owners car because if I made a scratch I would have to buy your Corvette fooooor about 20K
              • Randy G.
                • April 1, 2006
                • 358
                I'll give you a ride in it for $20K. Come to think of it, I'll give you $20K if you just fix the hood
                • Chris S.
                  • March 28, 2007
                  • 139
                  so adjust the stops so there is no give with the hood gasket? i think mine are rounded. Think i need to pull them to file sharp.
                  • Roy B.
                    • February 1, 1975
                    • 7044
                    Once the hood line is nice around the back area (closed) adjust the male stop so there is no movement when you push down with your hand , that way it cant giggle loose.
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      https://www.forums.ncrs.org/showthre...tment&uid=7666
                      I found my hood adjustment post , see if this can help you ROY
