The car is a '67 coupe, L79 with C60. I have read about various small changes to the splash shields, depending on model year and options (e.g., some having a rubber seal on the LH, and some not, depending on whether the car had A/C or side exhaust, etc.).
The RH splash shield that came off this car is rusted through (picture #2), and it doesn't look correct in configuration, it looks like part of it has been cut out with a tin-snip. It doesn't match any of the vendor catalog pictures.
Before I start searching for a replacement, I want to be sure of what I'm looking for. Is the correct part number 3797276? If mine is not correct, will an NOS example be the same as an original, or do I need to find a used original in this case?
Thank you,
Scott
Thank you,
Scott
26,000 miles.
