I am just finishing a complete restoration on my 64 convertible. Could someone please advise me on the proper installation of the front upper A-arm control stud for a 64? My book says the stud must be "pressed" into frame. What does this mean? How do I do it? The car is now totally "together" so how does one "press" the stud into the frame? Obviousy, I will replace the stud that is stripped. What did I do wrong?
I had a very scary, lucky or unlucky, depending on how you look at it event. I finally took my car around the block for it's first test drive at end of restoration. My passenger side A-arm must have lost the nut and when I went to brake hard to test my brakes. The A-arm nut came off and the A-arm swung around and hit my radiator shroud. This caused a very loud noise and then my fan began hitting the shroud due to a slight ding/bend that occured in the shroud. I have triple checked all of my suspension torques and cotter pins. However, after bouncing my new suspension, I remember having trouble getting the front upper A-arm control stud nuts to tighten to the 65-75 ft. pounds that my book calls for. They felt a little "funny" so I stopped torque at around 60 ft. lbs. I was thinking the alignment shop would torque them properly when I got my 4 wheel alignment. Also, I believe the one in question felt stripped.
Any thoughts would greatly be appreciated before I wrap my car around a tree.
Tim
Tim
