1968 VIN number - NCRS Discussion Boards
1968 VIN number
  • John T.
    NCRS Financial Officer
    • January 1, 1983
    • 293
    1968 VIN number
    Is the VIN number stamped on a 68 frame ? If so where ?
    John
    • 6960
    Re: 1968 VIN number
    John, I had a post recently on the frame stamp on my 72, its by the driver side #4 body mount and under the drivers side rocker in front of the #3 mount, but frame will have to be off to see this stamp.
    • Dick W.
      • 10483
      Re: 1968 VIN number
      John
      John, I have also seen them on the top of the kickup at the left rear wheel.
      Dick Whittington
        • 15640
        Re: 1968 VIN number
        C3s got the frame stamp in the same place(s) as C2s. Maybe, if the frame is not too rusted, you can see the one over the driver's side rear axle or there abouts. Might have to brush the top of the frame rail and use a mirror.
        • Dale C.
          • November 1, 1999
          • 844
          Re: 1968 VIN number
          John
          I found my VIN where Dick said. I took the wheel off and used a bright lite from behind and found the S413417 on top of frame kick up. It is kind of hard to see but recognizable.
          Dale
          • Dale C.
            • November 1, 1999
            • 844
            Re: 1968 VIN number
            John
            I'll try a picture. It's not very clear, in the picture, but you can make out the last two 17.
            Dale
            • Joseph K.
              • August 26, 2008
              • 407
              Re: 1968 VIN number
              That is were my number was on a 69. It was on the top of the frame behind the rear drivers side wheel and only visible with the body off.
              • Patrick N.
                • March 10, 2008
                • 954
                Re: 1968 VIN number
                John,
                Here is a pic of my 68 frame stamp near the driverside rear kickup. This stamp was light and very hard to find on my car. As mentioned the second stamp is towards the front near mount 3.
                Pat
                  Re: 1968 VIN number
                  You'll find it where Pat found his - on top of the frame, centered on the front edge of the #4 body mount bracket; it's stamped again about 12" forward of the kickup, about where your wallet is when seated in the car.
